Rings or Valves
My ZC is smoking only after warm up and acceleration, when the engine is cold there is very little to no smoke. After about 5 min warm up time its starts smoking am I looking at a full rebuild or maybe just valve seals and head gasket replacement.
do a compression test, record the numbers....and a few teaspoons of oil to the cylinder being tested, redo the test.....if the numbers go up then its your rings, if it doesnt then its your valve seals
natz20
Mar 15, 2008 09:55 PM
1.8T_EG
Oct 21, 2002 12:50 PM
