Very odd B series axle problem...
Motor is a B20B and is a JDM motor.
I bought a used midshaft and driveshafts from a guy who told me they were from a 99 Integra GSR. They fit into the midshaft perfectly fine once everything is in the car, however there is a slight problem with the midshaft. When I put it up against the block, it seemed as though 2 of the 3 bolt holes lined up, but the third has an 1/8" space between the block and the shaft. Here are some pics:
Is this the wrong midshaft? Someone said JDM blocks are different? Or this may be from an automatic transmission?
Should I be worried and go out and get a new midshaft or should I fill it with washers and bolt it up? OR should I bolt it down and screw it as tight as I can?
Originally Posted by thumper64
Is one warped or not flat? If you're just bolting it down tight, at least stick a washer inbetween to take the load.
TravisCadello
10
Sep 28, 2009 04:46 PM
crxhfpower123
24
Dec 23, 2002 09:23 AM
