96 Civic Ex Engine Dieing need to replace but confused and not sure what to get
Old Nov 9, 2008 | 07:42 PM
nnguyen22's Avatar
Default 96 Civic Ex Engine Dieing need to replace but confused and not sure what to get
I have a 96 Civic Ex Sedan Automatic and my d16y7 engine is burning oil and I need a new engine. I initially wanted to get a JDM D15B Vtec or d16Z6 but I was told that if my original engine did not have Vtec it would be difficult and a waste of money to get an engine with Vtec. The weird thing is that i thought all 96 civic's came with a d16y8 which has Vtec but for some reason I have a d16y7 non Vtec. If it turns out that I cant get an engine with Vtech what is the best engine I can get with around $700. I was looking at the D15B non Vtec but im not sure how much horsepower that has?
Old Nov 9, 2008 | 09:20 PM
86Stomper96EK's Avatar
Default Re: 96 Civic Ex Engine Dieing need to replace but confused and not sure what to get (nnguyen22)
All D series are interchangable except D17. D15B would be a decent swap,a Z6 would be better-wire in v-tec and run EX-D16y8ECU,or just buy the D16y8 and don't use v-tec....If it were me,which I have D16y7and buildingY8, and you want to stay D series,I would take the $700 and rebuild my D. You would have plenty of extra money to maybe slap on a Y8 head,ECU...etc. But as far as junk yards or someone that has done a B-swap...D15/16's are easily purchased for way under $700!!
Old Nov 9, 2008 | 09:30 PM
slo_hatch's Avatar
no the only civics that came with vtec in 96 were the ex coupes and sedans. and it is not that hard to wire in the vtec...look at the engine swap sticky at the top of the 92-00 civic forum. that is where you will find all your info.
then what would be the point of getting the y8?
Old Nov 9, 2008 | 10:14 PM
Default Re: 96 Civic Ex Engine Dieing need to replace but confused and not sure what to get (slo_hatch)
He said his didn't come with the y8...someone has already swapped? ...guess he needs to check his ECU...P2E=Ay7 or P2P=Ay8, he could have a y7 bottom end,y8head,+/or vtec sensor laying to side...go back and read before you criticize me!
Old Nov 9, 2008 | 10:19 PM
slo_hatch's Avatar
Default Re: 96 Civic Ex Engine Dieing need to replace but confused and not sure what to get (86Stomper96EK)
well if someone swapped the motor out for a y7 they should have swapped the ecu out too...and he wouldnt have SENSORS layin around...he would have the PLUGS but no sensors. and my fault for not reading that it was an EX SEDAN...that was my mistake. alot of people put y7 motors in cars that come factory with a y8 simply because they are cheaper.
OP: go look around and see if you have some wires laying around near the head. if you have 2 or 3 plugs just laying around...then you have a vtec wiring harness...which means the y8 will drop straight in with no modification at all.
Old Nov 10, 2008 | 10:11 AM
nnguyen22's Avatar
if i were to get a d15b non vtec, how much horsepower would it have because I am aware that there are alot of different types out there. As i said i have a d16y7 right now if i swapped it for the d15b would there be a significant amount in speed loss that i would notice while driving?
kkwick
16
Oct 6, 2020 11:46 AM
Cthenerd88
13
Apr 9, 2016 05:32 PM
munky_350
May 21, 2009 11:46 AM
nnguyen22
Dec 2, 2008 01:21 PM
hakkoo
Jan 12, 2006 02:00 AM
