help fast! axle wont come out of trans
good point if your pulling it out @ an angle it won't come out. They have a locking clip on the stem of the inner spindle to prevent them from coming out.
Good luck and try what was mentioned above.
Originally Posted by Garage 808 Hatch
if thats doesnt work, you may need to pull the other axle and drive it out from the other side
take a hammer and hit the cup it self and then pop it out with the pry bar. it may take a couple of hits on the cup but not to hard ok.
yes this does work i have gotten may mdx and tl's with the same problem and a good whack on the axle and then it will pop out.
Originally Posted by longshot
ok so the axle will not come out of the trans... i dont know why any suggestions?
d-series del sol..
d-series del sol..
use 2 thicker flathead screwdrivers on opposite sides of the axel, i just went through this BS a few days ago, i find if u apply equal pressure on both sides of the axel it comes out that much easier!!!
project91crxsi
Aug 21, 2009 05:56 PM
rice a roni
21
Apr 21, 2006 04:45 PM
