need help on 1/4 mile times
Old Jul 30, 2002 | 07:23 PM
spoonhbcivic's Avatar
Default need help on 1/4 mile times
i have a 99 civic hb with a b18c5 just put in, a spoon sports valve cover, spoon n1 exhaust, and a AEM intake. could someone estimate what my 1/4 mile times would be? [img]DSCN9999[/img] HOW DO YOU GET PICS TO WORK
[Modified by spoonhbcivic, 4:53 AM 7/31/2002]
Old Jul 30, 2002 | 07:47 PM
Default Re: need help on 1/4 mile times (dumpdlude)
i have the back and front seats striped. should i strip more
Old Jul 30, 2002 | 07:51 PM
slOwButXlentEK8's Avatar
Default wow
How much was your setup? if you have the b18c5(with the other mods) in the light dx body (lighter than the other civic models) your car should be running at least mid to high 14's...please correct me if i'm wrong
Old Jul 30, 2002 | 07:54 PM
Default Re: wow (slOwButXlentEK8)
cx body
Old Jul 30, 2002 | 07:55 PM
sloppy_seconds's Avatar
Banned
naw, maybe low 14's or high 14's....what kind of tires are you using? and what ECU are you using (re-chipped)?
and dude, the valve cover isn't a mod, so don't bother posting it
maybe you should launch a little bit harder, (like a higher RPM) or even try some sort of slicks or even drag radials.
hope this helps
--justin
Old Jul 30, 2002 | 08:02 PM
Default Re: wow (slowasscx)
i have yokohama parada on it right now but have nitto nt-555 shop
Old Jul 30, 2002 | 08:11 PM
JMX's Avatar
JMX
Default Re: need help on 1/4 mile times (spoonhbcivic)
no front seats and a spoon valve cover
at least 12's
Old Jul 30, 2002 | 08:20 PM
Default Re: need help on 1/4 mile times (jmx2323)
what kind of turbo should i get for my car
Old Jul 31, 2002 | 01:31 AM
slooowDX's Avatar
biggest one you can find
Old Jul 31, 2002 | 08:03 AM
Spinin4's Avatar
Default Re: need help on 1/4 mile times (slooowDX)
And don't forget to get higher compression pistons too.
Old Jul 31, 2002 | 09:28 AM
10seconds's Avatar
Honda-Tech User
well i dont see 12's in a 99 hb with a ITR motor and intake and exhaust. but why would you want to put turbo on a type r motor, it was made for all motor (imo) unless you feel like changing out compression, then go for it. i wouldnt recomend putting turbo on a high compression motor like that but thats me, do what you want
steve
Old Jul 31, 2002 | 09:45 AM
Freakn8's Avatar
Default Re: need help on 1/4 mile times (jdmimports79)
for your pics to work you need to upload them to a pic site like www.imagestation.com . then use the address for them up to .jpg and insert that address in between the [IMG][/IMG]. if you do that your pic will work
Old Jul 31, 2002 | 01:46 PM
Home Skillet's Avatar
i have a 99 civic hb with a b18c5 just put in,a spoon sports valve cover , spoon n1 exhaust, and a AEM intake.
glad you mentioned the valve cover. those are a must have in all drag cars. heres how you post a pic [IMAGE]location of picture[/IMAGE], but the html tags will be IMG and /IMG instead.
Old Jul 31, 2002 | 06:15 PM
Mase's Avatar
Default Re: need help on 1/4 mile times (Home Skillet)
Hell ya, those spoon valve covers weigh negative 17.422 pounds . a good anti gravity approach
[Modified by CDooMe2, 7:15 PM 7/31/2002]
Old Jul 31, 2002 | 06:20 PM
acuratypeRintegra's Avatar
jch
Old Jul 31, 2002 | 06:41 PM
EG_HB's Avatar
Default Re: need help on 1/4 mile times (acuratypeRintegra)
[Modified by SiRaccord, 3:44 AM 8/1/2002]
[Modified by SiRaccord, 3:45 AM 8/1/2002]
Modern91Hatch
41
Oct 12, 2005 08:39 AM
sp00led
Apr 12, 2004 09:48 PM
Jared
May 27, 2002 09:47 AM
gigantor
May 24, 2002 11:54 AM
CovertFI
May 21, 2002 03:16 PM
