90 DA GSR Swap help needed!!!!!
i have a 90 gs integra, 180,000 miles
im in the process of some major bodywork and interior restoration
i just purchased a gsr longblock and i am unsure about a few things
can i use my axles, they are brand new, it would be nice if they could fit
can i use my stock motormounts, will it just drop right in?
i am using my cable transmission as well
i hear if you don't use a p72 with a gsr stock intake, you will lose power in the midrange powerband. and a p72 harness will not fit with a da chassis
would a chipped p28 work with an aftermarket intake manifold, using an obd0-obd1 conversion harness
i would appreciate the help and anyone who can post pics of their da swaps please do, nothing better in my eyes than a cleaned up, swapped da
here are some pics of my da
like i said its definitely in the works i picked it up for 700 needing bodywork and paint, had a clutch with it, but i had to put it in the kid didnt know how
passenger sides done now, not recent pic, new bumper and headlights now
removed ac stuff
again
temporary brake fix, abs cylinder was cracked, losing brakes every two weeks had to bleed them i will clean it up run new lines when i pull the motor
removed ac stuff
again
yes you can, u just gotta use the Intermediate/half shaft as well.
yeah, use the stock DA passenger and driver side mounts, and i forgot about the rear L Bracket, just try the GSR first.
Upgrade to a Different Intake manifold, and use your OBD0 Engine harness, but keep ur alternator and Distributor..the think about the distributer is that u have to chop off a leg
i would just suggest getting a Pr3 obd0 vtec ecu. and hit up rywire for the vtec sub harness.
http://www.g2ic.com/tegtips/engine/15.html
go to the engine swap guide and look around in there.
axles as stated used with intermediate shaft. motor mounts and core mounts can be used ALL four, core mounts mean the part that bolt from the mount to the engine/trans, cable trans will bolt right up assuming you use same clutch disc, yes chipped p28 aftermarket intake and conversion harness will work.
i know this because i have a gsr in my 91 da
thanks man i appreciate the input, just want to do it right and all in one day
not have to deal with working on it forever
anyone have any pics, feel free to post them i would love to see some pics of everyones da gsr swaps or any da swaps just to get a feel
i don't mean restoring it all, i am going to pull the motor and all things i need to first, whenever i get my motor i want to drop it in and do it all in one day, i swapped a b16 in my friends ls in a day, and then reswapped a 98 spec ls back in it when his wiring fried
question, do i have to swap dizzy internals, if so why, shouldnt an obd0-obd1 conversion harness allow me to just plug in my distributor as normal?
heres a little motivation!
