Integra 5 Speed Swap into EG Body
Ok. I did the search, I can't find anything. I got a del slow automatic and got my hands on a free LS. I was wondering if the manual swap was complete bolt on over to the other side as in the petal assembly, throttle cable, clutch cable, slave lines, etc. Anyone with any insight that can shed some light would be great. Thanks.
I plan to use everything including the motor tranny and ecu. Im sure ill have to modify the linkage to make it fit right though. I am just making sure the petal assembly will bolt up and I wont have any issues. The rest should be cake work. Do you know if the assembly works?
Originally Posted by 94EG8
Pedal assembly is exactly the same as an EG setup. And you will either have to modify the shift linkage or buy one for a Del Sol Vtec.
If your 100% sure im going to start ripping apart two cars.
LittleBigWelsh
May 19, 2013 01:33 AM
j4s0n1337
Dec 29, 2010 04:35 PM
