noob to turbo got some question to maintain
Old Nov 8, 2008 | 10:59 PM
sDc5's Avatar
Default noob to turbo got some question to maintain
i recently got a ej1 civic ex d15 with a vtec head and has a drag turbo kit running 5-6 pounds just wanted to find out the things i should look out for or things i should make sure i do other than frequent oil changes and turbo cleaning, not too sure what i can or should do to take car for a daily driver. advice and positive opinions are appreciated
Old Nov 8, 2008 | 11:33 PM
mattyv's Avatar
Default Re: noob to turbo got some question to maintain (sDc5)
first thing id do is check the spark plugs and make sure their not iridium. you dont wanna be making to much heat when boosting
Old Nov 9, 2008 | 03:00 AM
Ek4 life's Avatar
Default Re: noob to turbo got some question to maintain (mattyv)
what kind of plugs do you use then?
Old Nov 9, 2008 | 05:27 AM
SDHonda153's Avatar
Default Re: noob to turbo got some question to maintain (Ek4 life)
A cooler burning NGK, like a BKR7E or a BCPR7ES. There good for up to 450 whp, so they'd be perfect in your application
Modified by SDHonda153 at 9:15 AM 11/9/2008
Old Nov 9, 2008 | 05:38 AM
ns060's Avatar
Default Re: noob to turbo got some question to maintain (SDHonda153)
dont drive it like your in the fast the furious
Old Nov 9, 2008 | 06:14 AM
SDHonda153's Avatar
Default Re: noob to turbo got some question to maintain (ns060)
Does it have a turbo timer on it? If not, I'd look into getting one of those to help maintain your turbo and keep the inside from gumming up.
Old Nov 9, 2008 | 05:25 PM
sDc5's Avatar
yea it was in the trade
came with a blitz turbo timer with other functions
looked into it and found the drag manifold isn't really the best for boost and flow
not sure if any one out there has had problems with drag manifolds seems like the setup i have was pieced together. car runs great and saves gas haven't taken apart the turbo to see if there is any play with the blades.
Old Nov 9, 2008 | 05:31 PM
jimmy o.'s Avatar
definately run 93 octance if you are not already to prevent detoniation under boost.
Stingray96
Sep 6, 2005 03:12 PM
The Weather Man
Jul 27, 2005 09:44 PM
sykotic
Mar 15, 2005 03:05 PM
2K1NBGSR
Mar 6, 2002 10:19 AM
