Tachometer Problems...
Old Nov 8, 2008 | 02:52 PM
NightHawkBlack-R's Avatar
Default Tachometer Problems...
I have a USDM 01' ITR with a JDM 98' ITR motor. My tach works, but once it gets past 6,000 RPM the needle goes straight down to 0. I bought a brand new distributor for the car but it doesnt show any RPM at all, so i'm not sure if its the distributor now. Can someone help me please?
Old Nov 9, 2008 | 07:38 PM
jdm2u's Avatar
when mine did something like this took tach out was grounding issue behind it
Old Nov 10, 2008 | 03:42 AM
walker111's Avatar
Default Re: Tachometer Problems... (NightHawkBlack-R)
Are/were there any perfomance loss when the tach drops? or is it just the tach? Original guage cluster?
Old Nov 10, 2008 | 04:41 AM
cmdr430's Avatar
Default Re: Tachometer Problems... (walker111)
on this same note, does the car sound like it is bouncing off of the rev limiter when it shows 6k rpm on the tach?
If so, you may be running in limp mode.....
Which is where I think Walker111 is going w/ his question
Old Nov 10, 2008 | 06:57 AM
MOVE OVER's Avatar
what ecu? stock ecu or a chipped OBD1 computer?
Old Nov 10, 2008 | 11:08 PM
Its just the tach, the motor runs fine after the tach drops to zero. I have a chipped P28 ECU.
Old Nov 10, 2008 | 11:09 PM
Default Re: (jdm2u)
I'm thinking its a ground, if so where exactly behind the gauge cluster is the ground for the tach?
Old Nov 11, 2008 | 12:44 PM
Here is a picture to help what may the problem. there is a stray wire coming from the gauge cluster to the engine bay that has been cut a stripped. someone that had the car before me has had an aftermarket tach in the car before.
Old Nov 11, 2008 | 03:50 PM
mikestypeRR's Avatar
quite the fire hazard you have there.
coot_er
11
Apr 1, 2020 04:45 PM
hondacivic90zc
12
Jul 3, 2009 08:57 AM
3rdGteg
Jun 5, 2006 02:36 PM
frostee trooper
Feb 6, 2005 10:58 PM
