Taillight fuse blows
Old Nov 8, 2008 | 02:24 PM
twiztid00002's Avatar
Default Taillight fuse blows
the 15A tail light fuse in the drivers kickboard blows once i turn on my lights,, so i have no tail lights or dash lights at night??? anybody know?
it used to only blow when i pulled my E-brake while my lights were on but no it just blows by turning on my lights.
5th gen
Old Nov 8, 2008 | 06:23 PM
KennyN's Avatar
Default Re: Taillight fuse blows (twiztid00002)
guess u need to change a new one.^_^
Old Nov 8, 2008 | 06:45 PM
dagle's Avatar
Default Re: Taillight fuse blows (KennyN)
break in the circuit, find exposed wire or something not hooked up right..
Old Nov 8, 2008 | 07:29 PM
Default Re: Taillight fuse blows (dagle)
where would i go about finding this wire? like in the drivers kickboard, lights switch, etc?
Old Nov 8, 2008 | 09:21 PM
luxlude's Avatar
mine did that when i changed my radio in my third gen. one of the wires was grounding itself out. yours sounds a little different but it wouldnt hurt to check. also you say it started when you pulled your e brake? check along where your ebrake runs and see if it rubs any wires.
Old Nov 9, 2008 | 05:57 PM
Default Re: (luxlude)
ok, so now its worse. now once i turn on my car even with my ebrake down without turning on my lights the 15A fuse (interior lights) under the hood blows, which control all my inside lights, my headunit and gauges, and door lights.
anyone have any ideas??
Old Nov 9, 2008 | 07:38 PM
Kronn 98SH's Avatar
Default Re: (twiztid00002)
It sounds like you have a short somewhere. The only way to diagnose it would be with a multimeter, unless you get lucky and find visible signs of it. I would take it to an automotive electrician.
Old Nov 10, 2008 | 07:42 AM
Default Re: (Kronn 98SH)
ok i fixed the problem. it was because of the ebrake. the sensor part that tells u on the dash whether your ebrake is on or not, i guess something was wrong with the wire so i just disconnected it, so wen my ebrake is on it just wont tell me on the dash but i dont really care about that.
Gatschet
23
Aug 25, 2021 10:35 AM
my93civiceg
Feb 8, 2009 11:04 PM
Toanz
Sep 26, 2008 08:22 PM
JDMFEVER
Jun 27, 2008 04:43 PM
