Caliper slider pins?
I am doing a bake job on my 1998 Honda Accord coupe and it is time to reassemble the calipers onto the caliper mounting bracket and I noticed that the caliper slider pins are different on pin has a small rubber on the end of it and the other doesn't.
Of course since I did not notice this difference when taken it apart I did not keep track of which pin went where?
Does anyone know if the pin with the small rubber at the end goes on the top or bottom?
Thanks
Thanks
I think it goes on the top. Use this link and enter your car info. to see the brake parts illustration, and you'll see it.
http://www.slhonda.com/parts/wholesaleparts.htm
If we are talking about the same thing, there are 2 pins. Each about 3" in length. They usually have a marking on the head of the pin. L & G. L goes in the lower holes...and you can guess where the G goes.
One other quick question, anyone know what those shims on the the brake pads do? they are numbers 10, 11 and 12 on the bottom diagram?
thanks
thanks
Really noise control hey!
So if I am using after market pads should I not use the shims? I am installing Hawk Performance pads with Power Slot rotors. Would it be better to just lube up the pads instead?
thanks
thanks
Calif_Kid
Apr 2, 2014 04:12 PM
raverx3m
Suspension & Brakes
Aug 22, 2013 11:09 AM
