TAPPING REALLY LOUD
HEY GUYS I HAVNT POSTED IN AWHILE I HAVE A 98 CIVIC EX STOCK D16Y8 THE OTHER DAY I WAS DRIVING THROUGH THE HARBOR TUNNEL AND I WAS PULLIN PRETTY HARD HIGHEST WAS MABY WAS 6500 RPMS JUST BEIN GOOFY CAUSE OF THE WS2 EXHAUST IN THE TUNNEL SO I COME OUT PAY THE TOLL AND BEFORE I MAKE IT OUT CAR BOGS OUT START IT UP GO DOWN THE STREET ENGINE STARTS TAPIN OR KNOCKIN OR SOMETHING STARTED A LITTLE LOW THEN GOT REALLY LOUD ALMOST MADE IT HOME BUT DIDNT WANNA MAKE IT WORSE THAN IT ALREADY WAS FOUND OUT BEFORE I PROCEEDED HOME WAS 1 1/2 QTS LOW ON OIL HOW I HAVE NO IDEA I REALLY GOOD ABOUT KEEPIN UP ON THAT STUFF WHATS IT SOUND LIKE I GUESS IN BENT VALE IT SOUNDS LIKE THE 2ND IN FROM THE PASSENGER WHEN FACING THE ENGINE IF ANYONE NEAR MD HAS A DIRECT SWAP OR SOMETING CHEAP LET ME KNOW I GOT FIRED CAZ I COULDNT GET TO WORK TRAINING SO NO BIG SPENDING RIGHT NOW
Chances are that you didn't bend a valve at 6.5k...Are you sure that it's a valve tapping? Could be rod knock. Does it get louder by rpm? Oil starvation at high rpm is bad.
Originally Posted by camaro-killer
Rod knock from bearing failure due to oil starvation?
Originally Posted by littleblue
I need laser eye surgery after reading that.
Originally Posted by jbrokos307
why is that
O SORRY LOL jk i figured readin caps makes it easy
youve spun a rod bearing ive done it my self. really common in y8 blocks. with that said your motor is shot. find a d16z6 and do a swap try the search engine( type in "d16y8 to d16z6") to find out info on the swap ill help you to get a start. this is the best one ive found when it comes to info buy theres 8 more to read over
https://honda-tech.com/zerothread?id=2420417
when did the swap the hardest thing to do was to relocate that damn ITA sensor but other than that it was a breeze heres a site to get an obd1 to obd2 wireing harnest
http://www.evasivemotorsports....FkrOw
@Dkober101: nice link and details.
how come HMotors does not have a z6? is it not a common swap?
found in:
# 1991-1992 Honda civic si
# 1992-1995 Honda Civic EX, EX-V and SI
# 1992-1995 Honda Civic ESi (European Market)
# 1993-1995 Honda Del Sol Si (US)
# 1993-1995 Honda Del Sol ESi (European)
found in:
rovafa2002
24
Nov 18, 2013 01:35 AM
.Slug
Jun 5, 2006 09:52 AM
