And so my 89x95 Build Starts
Old Nov 7, 2008 | 10:07 AM
Lude@Heart's Avatar
Default And so my 95x89 Build Starts (CAUTION 56K NO NO)
<U>Im looking for the following parts for this build PM me if you have them:</U>
Nothing at the moment
Well its about time i get to throw one of these posts up here.
I have recently got my hands on a ERL built H22 block with Darton Sleeves built for boost from my buddy.
One or more valves dropped and destroyed Piston #3 (see pix) He let me have the whole block for doing some wiring on his car so I jumped on it like a fat kid on cake.
I took it to work with me today and started tearing it apart.
http://i30.photobucket.com/albums/c3...orBuild001.jpg
http://i30.photobucket.com/albums/c3...orBuild002.jpg
http://i30.photobucket.com/albums/c3...orBuild004.jpg
http://i30.photobucket.com/albums/c3...orBuild005.jpg
http://i30.photobucket.com/albums/c3...orBuild006.jpg
I believe the Root of the Evil was the Auto-Tensioner. Causing Belt slippage and lovely piston to valve contact on Cyl #3.
Ill have everything out of the block by tonight and then all I need is a set of ARP Main bolts and it can go to the machine shop for:
-Overbore from 87-89 (hopefully that will take the damaged sleeves back to perfect condition)
-Line Bore the mains
-make sure block deck is true
-Hot tank
Setup will be as follows:
-Darton Sleeved H22a block
-Wiseco 6.5cc 89mm pistons
-Probe I-Beam Rods (deciding on getting them from Import Builders $325 or straight from Probe $275, does Jeff do anything special to them?) Im only assuming jeffs rods are the same as IB dont quote me on this.
-Brand new OEM H23 Crank
-Stock H22a4 head for now with Type S cams
-ERL BS removal kit (2 plugs in oil pump and turned bearings) as well as Rosko Cover plate
Below is always the most up to date status:
So the block is at the machine shop now, I went to the machine shop on Friday but i guess they decided to stay closed all weekend. So ill find out Monday whats going on.
In the meantime I took some preliminary measurements of my Crank. Its brand new. So specs should be very even. I took 2 measurements 90 deg. from each other.
Main Journals:
1. 1.9688”
2. 1.9688”
3. 1.9687”
4. 1.9687”
5. 1.9687”
Rod Journals:
1. 1.8899”
2. 1.8898”
3. 1.8898”
4. 1.8899”
Of course im going to recheck clearances when i get my block back and do it at the same time so i don't get different measurements due to heat expansion or contraction.
Old Nov 7, 2008 | 10:11 AM
McLude2nR's Avatar
yesssssssssssssssssssssss... my car lives on in the body of another. Thanks for aiding in my goal of immortality
LOL at my tinfoil piston...
Old Nov 7, 2008 | 10:37 AM
spectacle's Avatar
Default Re: And so my 95x89 Build Starts (Lude@Heart)
You better [freak]ing boost it Mario or i'm punching you in the face.
Old Nov 7, 2008 | 12:06 PM
Lude@Heart's Avatar
HAHA there he is, McLude2nR is the block donor.
It will run again!!!
And no way am i gonna boost it my friend. You should know me better then that.
Old Nov 7, 2008 | 12:35 PM
Lude@Heart's Avatar
Default Re: (shutta)
lol can of worms has been opened.
On a B series maybe, on a H22, we need sleeves to go big.
Old Nov 7, 2008 | 03:28 PM
2fastGSR's Avatar
King of the One Liners
Originally Posted by shutta
it's a waste of a sleeved block to not go FI... to each his own...
Worst comment
Ht at its best
Conform or be flamed. Imposing one's own will till the end !
Throw some compression at her, some nice cams and drive the **** out of it . .
Old Nov 7, 2008 | 03:49 PM
Lude@Heart's Avatar
Default Re: (2fastGSR)
Originally Posted by 2fastGSR
Worst comment
^ This man understands
Boost is fun and all. But I respect a NA 4 cylinder a lot more than a boosted one.
Old Nov 7, 2008 | 03:50 PM
ShoofIsLudin's Avatar
oh damn.....i don't think u guys know what this is gonna turn out to be....
Now the hatch will NEVER get traction. I thought McLudes car was nasty.... I remember seeing his car burn out thru 3 gears vs an SRT4.
Any word on how the valve dropped? Keeper come out or did the valve head break?
Old Nov 7, 2008 | 04:07 PM
Lude@Heart's Avatar
i think the tensioner failed, belt skipped, number 3 hit a valve broke it off, and thats that
Old Nov 7, 2008 | 04:38 PM
bad1_s2k's Avatar
nice piston! lol. same thing happened to my motor about 2 weeks ago! 2 holes in piston #4 and I found the valves in my oil pan lol
Old Nov 7, 2008 | 08:28 PM
Rosko's Avatar
Default Re: (bad1_s2k)
HELL YEAH MARIO!! Good luck buddy
Old Nov 7, 2008 | 08:46 PM
teefunk01's Avatar
Default Re: (Rosko)
those pistons took some damage lol
new block and pieces look good
Old Nov 8, 2008 | 05:14 AM
Lude@Heart's Avatar
Thx for all the support guys. It will get rolling in no time.
Old Nov 8, 2008 | 12:37 PM
NirVTEC's Avatar
It'll buff right out.......just use some Gorilla Glue to fill the hole! lol
Great potential setup....I will be checking on this thread!
Now you need some Cams!
Old Nov 8, 2008 | 01:39 PM
98vtec's Avatar
moderator emeritus
Default Re: (Rosko)
funny that us three all run the same crank, rod and piston setup
Old Nov 8, 2008 | 08:09 PM
Lude@Heart's Avatar
Default Re: (98vtec)
no shawn has 88s 89 ftw!!!
Old Nov 9, 2008 | 03:08 PM
bad1_s2k's Avatar
those pistons look rediculous!
Old Nov 9, 2008 | 05:08 PM
98vtec's Avatar
moderator emeritus
its just a little dome
Old Nov 10, 2008 | 05:38 AM
Lude@Heart's Avatar
Its only gonna stick out the block a little to make more compression, no big deal
Old Nov 10, 2008 | 06:03 AM
NirVTEC's Avatar
H23 crank/rods and Wisecos?
What is the H22 Compression of the Wisecos? Are THEY really the best to go with?
Old Nov 10, 2008 | 06:10 AM
98vtec's Avatar
moderator emeritus
Default Re: (NirVTEC)
IIRC, 11.5:1
Really, any brand name piston will get the job done.
Old Nov 11, 2008 | 07:50 AM
NirVTEC's Avatar
So who is doing the 90mm slugs these days?
Old Nov 11, 2008 | 08:15 AM
Rosko's Avatar
I believe Natalie is running 90's. Wiseco to me has always seemed to be the way to go. They are no stranger to high revving motors, i.e. dirt bikes/quads/motorcylces.
Old Nov 11, 2008 | 12:48 PM
Lude@Heart's Avatar
Currently waiting on ARP Main Studs, Machine shop quoted me $109 (IF Anyone has a set and can beat that price shipped to my door then PM me asap)
Old Nov 11, 2008 | 01:08 PM
mattsnooz's Avatar
Default Re: (Lude@Heart)
I cringed like 6 or 7 times looking at those pictures. That piston # 3 is FUKKKed worse than that I have ever seen in person or in pictures. Theres like nothing left in the bottom lol. Cool build though, and good job going NA, to that!!
good luck
