And so my 89x95 Build Starts
#55
I'm still working on figuring out where i can find a set of Red Main bearings. We don't carry the Reds any more. If i cant find any I'm going to just grab a set of pink ones and see what clearance the plastigauge gives me.
Shawn (rosko) has my oil pump in his possession, hes going to clean up some of the scarring, as well as deburr the gears and use new Allen head hardware.
^Update: Im going to buy a new Oil Pump to be safe, Shawn found some pretty bad scarrs in the old one.
Also if i cant find a set of H23 rods I'm debating on having the crank offset ground to use B series rods. I want some of you gurus to give some input to this.
I'm going to be on vacation in germany till Jan 2nd so look forward to some updates after that since I will have some parts come in while im gone.
#56
Re: And so my 89x95 Build Starts
Back from vacation boo!!! But at least i have some funds to continue this build. My new oilpump came today which is going to be shipped out to Rosko in 2 days. I also ordered the IB rods today, should be here in a few days.
I ordered 4 Pink bearings im going to pop them in journals 2 and 4 and lay the crank in and tq it down, measure clearance with plastigauge and see if im at the desired .0018"
or at least close, since pink is the thinnest bearing I can get from Honda.
We will go on from there.
#57
I looked a little further into the Oring on the back of the block issue that some of you are having. My New pump did not come with it, but i was able to order it seperately. When i get it im going to see if it fits or not. Ill keep you posted.
#58
Well I can get all the part numbers from slhondaparts.com but those two orings just dont show up in the 5th gen catalog for some reason.
http://www.hondaautomotiveparts.com/...P-OIL+STRAINER
http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
The oil pump oring is wierd in that people who've ordered 4g and 5g oil pumps have received them without it installed, and that slot not machined properly.
#62
Ok so its been a hell of a long time since ive updated this but thats life, anyway things are coming together, ill post pix tomorrow.
Block is assembled and the heads at InlinePRO
Currently working on the engine bay. Tuck, repaint, the works.
stay tuned
stay tuned
#63
WOW u dont realize how fast time flies till u update one of your posts from ages ago LOL
BUT the good news is this motor will finally see some running time.
I will be running a stock H22 head for now still cause I can not afford for CombustionContraption to port it for me.
The Skunk2 Pro2s i had in the OEM block b4 are also going to g nicely with this.
Rosko ran some numbers for me and since the pistons stick out .047 im gonna run a .084 Cometic Gasket which yields right around 12:1 CR still
I need to buy the headgasket and have Randy send my cams back as soon as I can afford to buy gears for em.
Hoping to have this up and running by IFO next month!
#66
Thanks guys!
Tax returns are comin so Ill be able to get this on the way in no time
Pirate hows things been man, always good to see you post up.
Ill have more pics soon as i get some more stuff hehe
#67
Sounds like a pretty solid way to live. Schools kickin my *** and funds are low cause I dont work much with it but other than that I still have enough to get a motor together slowly so I guess I cant complain lol
#68
I never did post pictures of what the motor is goin in (these are with the stock motor that was in b4)
#70
sick work dude much props. Your in Tampa? Im right below you in sarasota, do you bring that thing out to shows?
And where did you get all the harness boots?
#71
thanks guys. Yeah im in Tampa, as long as I get the diff, headgasket and cams in by monday ill finish engine assembly Wednesday and dyno on friday that way I can take it to IFO in Gville on Sunday.
I honestly forgot where I got the boots from ill look and see but next time Im definitely using Raychem cause they are much nicer.
#72
my harness came out like crap compared to that lol those boots are much nicer then heatshrink. Where do you get your tunning done? I went through phearble hes $$$ but did a good job
#73
Rick from InlinePRO is the only one other than me to ever touch my car as far as tuning goes. Im on AEM EMS
