GLOW GAUGES ? and INSTALL ?
hey i got sum used glow gauges . there in a case the km dont match my cars km so is there a way to turn them back ? is it possible to take the gauges out of the case and hook it glow gauges to my stock gauge case so the km would be from my lude.
i have never hooked them up before so could someone give me detailed instuctions please include where to hook them to my headlight switch so i can turn on the gauges with my headlights.. also need to know where to hook it up to the power source.
if u have an aftermarket headunit....use the orange (illumination) wire to light them up.
Or go to the fuse box, and use a multimeter and test for ~12.0ish volts when u turn the headlights on
ok i need help i just changed the gauges .i removed the speed tack needle and the fuel gauge needle to put on the gauges and now they both do not work niether does the odometer it wont count km can somone help me
sublimnal
61
Nov 4, 2008 09:02 PM
nocturnaldragon
23
May 3, 2004 03:01 PM
