Err..some b20/vtec questions
Did a search and i read a lot of topics, but i just had a couple ?s...
b16 head unmilled w/ oem headgasket
(which one?) .5mm or 1mm oversize valves
toda spec C's
~12:1 ish ImportBuilders weisco or ???? pistons in a b20 block
Am I going to have piston to valve or valve to valve clearance problems?
toda spec C's
I've only heard good about Weisco pistons, Im considering buying some from Jeff at IB too. There are also Ross pistons, a lot of pros use those too, and they're supposed to be priced right. If you buy them from IB, tell him what you've got and Im sure he will have the pistons. He does frankenstien engines all the time and they hold together.
darkintegra
54
Jun 26, 2017 09:19 AM
JCushing
Oct 25, 2002 06:14 AM
JCushing
Oct 23, 2002 04:56 PM
