DIY motor mount reinforcing?
Old Jul 30, 2002 | 02:36 PM
W.O.T.'s Avatar
Default DIY motor mount reinforcing?
I once saw a post / website showing DIY motor mount reinforcing with 3M window weld in a tube. Hours of searching have been fruitless. Anyone help me out?
Is window weld stuff as stiff as motor mount inserts?
I assume you'd want to do the torque mounts - rear and two lower fronts right (not top side two).
Any other comments?
Aaron.
Old Jul 30, 2002 | 02:58 PM
2000_Civic_Si's Avatar
Default Re: DIY motor mount reinforcing? (W.O.T.)
I have heard of doing this before. I was told to just use the strongest thpe of sylicone I could find. But if there is s omthin that is stiffer then I am sure it would work better.
Old Jul 30, 2002 | 03:07 PM
JV's Avatar
JV
Who?
Default Re: DIY motor mount reinforcing? (2000_Civic_Si)
http://www.homemadeturbo.com/poly.html
http://importnut.net/motormount.htm
[Modified by JV, 7:08 PM 7/30/2002]
Old Jul 31, 2002 | 08:38 AM
W.O.T.'s Avatar
Default Re: DIY motor mount reinforcing? (JV)
That's the site I was looking for. Thank you very much!
Aaron.
Old Aug 8, 2002 | 02:43 PM
noodles806's Avatar
W.O.T., after you try this, please tell me how you like them - the dealership said that one of my mounts iscollapsed, and this looks like a quick, easy, and most important, LOW-COST fix for my problem...so hopefully it's good! Thanks...
Old Aug 13, 2002 | 08:38 AM
W.O.T.'s Avatar
Default Re: DIY motor mount reinforcing? (noodles806)
Ok, I've done it. Keep in mind that my hatch is stripped and I did it while swapping so I don't have much for comparison.
I did the three torque mounts. Fulled 'em full.
It shakes slighty at idle. Like a really mild back massage. Other than that, I don't notice much vibration. Throttle response is instant, wheel hop is near none.
I'd recommend this mod.
Aaron.
Old Aug 13, 2002 | 08:41 AM
Spade's Avatar
Sweet. for u.
Did you take the mounts out or do it with the mounts in the car?
[Modified by Spade, 9:42 AM 8/13/2002]
Old Aug 28, 2002 | 01:52 AM
jim helms's Avatar
check out the jimfab.com mounts or try shoe goo, you will need to take the mount out for bolth fixes
nick91civicsi
Apr 6, 2008 07:59 PM
onyx00
Sep 24, 2004 01:00 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
B_1_8_hatch
Feb 17, 2003 06:50 AM
Briman2021
Jan 31, 2003 09:17 PM
