Problem with car wont crank over
I have been letting my little bro use my civic and its been driving great until 2 nights ago he calls me up and says the car wont crank at all. I go meet up with him and when he turned the key forward to crank it there was no fuel pump prime, a weird electrical noise was coming from the passenger side dash and when it made the noise the guage cluster lights would dim and flicker like it was loosing power.
So i checked the battery 12 volts
Took the main relay from my r and put it and the fuel pump now primes.
also switched out ecu with another working one.
But when you go to crank it, it still makes a weird electrical noise like something is shorting out and the guage cluster still dims out and flickers. So i disconnect the starter signal wire to see if anything would change and it did. Now when you crank it you can just hear the starter relay click. So i had another starter laying around thinking the one in there was shorting out but still does the same thing.
I am confused on whats going on and was hoping you guys can please help me out here
Modified by ITR.#1446 at 3:38 PM 11/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 »</TD></TR><TR><TD CLASS="quote">no one wants to take a stab at what the problem is?</TD></TR></TABLE>
Okay... try the Civic forum. Adios
my del sol did that at times....come to find out a prior owner had installed an alarm system and never removed it and was causing my car to freak out...
so shrug maybe look for that? or check for exposed wires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude »</TD></TR><TR><TD CLASS="quote">
sure thanks for the help..... it's funny if you look threw the itr forum there really isn't any technical threads anymore
thrule01 thanks ill take a look under the dash and see if there is a system in there or signs that one was in there
</TD></TR></TABLE>sure thanks for the help..... it's funny if you look threw the itr forum there really isn't any technical threads anymore
Modified by ITR.#1446 at 3:38 PM 11/6/2008</TD></TR></TABLE>
did you try a different battery?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">
battery had 12.5 volts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IBriaIN »</TD></TR><TR><TD CLASS="quote">starter?</TD></TR></TABLE>
tried a different starter
in the CIVIC forum i was suggested to check the ground which i was thinking may be the problem also
did the battery have 12V when you were cranking?
When there is no load on the battery, measuring the voltage is pretty pointless.
I hope not but i only have one ground on the motor and the spot on the frame rail was stripped alittle so i am gonna check it tomorrow im hoping thats the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 »</TD></TR><TR><TD CLASS="quote">I hope not but i only have one ground on the motor and the spot on the frame rail was stripped alittle so i am gonna check it tomorrow im hoping thats the problem</TD></TR></TABLE>
How about you fix it the way its suppose to be and see if that does it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">
How about you fix it the way its suppose to be and see if that does it.</TD></TR></TABLE>
I think he is planning on it?
Yeah i had my brother mess with the ground and he said it was no change but he tried to crank it again 10 mins later and it started. So yes its a ground problem and i will fix it just haven't had time to get to my brother's house.
ITR.#1446
Nov 7, 2008 10:40 AM
