speedo problem
well i purchased a 90 accord ex automatic. stock ,the problem that i'm having is that the odometer isnt working, the rpm gauge is fine, i replaced the speedo sensor and it didnt fix it, im told that the ecu might be the problem help!!!!!!!!!!!!!!!!!!!
It's either dash wiring (someone cut something they shouldn't) or the cluster itself.
If the ECM were malfunctioning, The "Check Engine" lamp would be lit.
If it had been the VSS (Vehicle speed sensor), I've seen both the D4 and the CEL lamp come on.
Cluster failures are not uncommon.
P
P
More than likely.
You can sometimes find a replacement cluster thru several venues
1) Your local auto parts recycler.
2) Ebay
I know of no repair services (sorry)
P
2) Ebay
P
mikej94civex
May 25, 2010 05:09 PM
