Low Idle
Old Jul 30, 2002 | 01:49 PM
Turbo Powa's Avatar
Default Low Idle
I dont know whats going on. Maybe some of you might have an idea? Sometimes when I idle the car drops to about 750 rpm. Its usually around 950. Is it ok to leave it alone or should I go get it checked out? With AC on its about 950. Its usally about 1150 rpm.
Old Jul 30, 2002 | 03:27 PM
gohandbz8's Avatar
Default Re: Low Idle (Civic LX 29)
Its probably ur OBD thats causing it and its common. I've seen ITRs that changes idle. Sometimes it can jump upwards to 1500rpm.
Old Jul 30, 2002 | 03:39 PM
allmtr's Avatar
it sounds ok. no major problems.
Old Jul 30, 2002 | 03:43 PM
Turbo Powa's Avatar
Default Re: Low Idle (allmtr)
R U sure? I feel like I've lost alot of power and my throttle response sucks now. I got to give it some really hard gas for it to rev higher.. Maybe I'm just paranoid?
Old Jul 30, 2002 | 03:58 PM
Turbo Powa's Avatar
Anyone else have any ideas?
Old Jul 30, 2002 | 03:59 PM
DSC's Avatar
DSC
Its normal.
Its a Honda. Got no low end torque.
Old Jul 30, 2002 | 04:19 PM
johnnyblaze's Avatar
It's no problem. Sometimes when the car gets to a certaind age or milege you just half to ajust the throttle a little. I wouldn't worry about it.
Old Jul 30, 2002 | 04:40 PM
Turbo Powa's Avatar
Default Re: Low Idle (johnnyblaze)
How would I adjust the throttle? I dont know much about cars. Do you recommend any sites?
Old Jul 30, 2002 | 05:07 PM
Turbo Powa's Avatar
Anyone?
Old Jul 30, 2002 | 05:20 PM
neveronlines2k's Avatar
To adjust the idle you have to turn the screw that on the throtle body. On mine its a brass looking flat head. After you adjust it reset the ecu or it wont change that much. I would also only turn the screw half way each time and log it on paper so you can set it back if you want. Or do it the easy way and take it to honda good luck hope that helps.
BTW my SI used to idle at 900-1000 now idles at 700-800 and it's normal no problems . In the honda dealership manuel it says not to worry about the idle unless under 550rpm.
Old Jul 30, 2002 | 05:33 PM
Turbo Powa's Avatar
Default Re: Low Idle (stuckatworksi)
Thanks stuckatworksi!!! I'll try to adjust the throttle cable.
Old Jul 30, 2002 | 05:38 PM
acuracing's Avatar
I would leave well enough alone or else we're gonna get a new topic on this board titles "Help, My Car Won't Start!". 750 is not that low of an idle. The normal idle for an ITR is 850 plus or minus 50. Your sounds fine. If it fluctuates from 750 - 1500, then I would say you have a problem then...
Old Jul 30, 2002 | 06:15 PM
Turbo Powa's Avatar
Default Re: Low Idle (acuracing)
I doesnt fluctuate like that. Sometimes it would be 500 rpm and sometimes it would be about 900. My car used to respond well uuntil about 2 weeks ago. No it drives like crap. I have no idea whats going on.
Old Jul 31, 2002 | 10:43 AM
FlatEric's Avatar
when you put your intake in did you reset your ecu?
Old Aug 1, 2002 | 11:04 AM
Turbo Powa's Avatar
Default Re: Low Idle (FlatEric)
Of course. I tried to reset the ecu but it didnt work. I still did not adjust the throttle body yet. Anyone still have any ideas? Should I adjust the throttle?
Old Aug 1, 2002 | 11:45 AM
VtecMatt's Avatar
My 95 EX idles at about 600-700rpms, been that way since I got it over a year ago. I have friends with Civics that idle about the same way...no problems yet!
(knock on wood)
Old Aug 1, 2002 | 03:54 PM
Turbo Powa's Avatar
Default Re: Low Idle (VtecMatt)
So I shouldnt worry about it ey? Throttle response sucks but oh well. If anyone have ideas let me know. Thanks!!
Old Aug 1, 2002 | 06:05 PM
Turbo Powa's Avatar
Anyone?
Old Aug 2, 2002 | 06:29 AM
Power1Pete's Avatar
Anyone?
try the PCV valve. Good luck.
99d-series
May 18, 2009 04:51 PM
Bizarre
Sep 6, 2007 09:40 AM
redED9Si
Aug 21, 2005 06:58 PM
stRodda
Jan 13, 2004 04:32 PM
Balls
May 23, 2002 08:59 PM
