Check Engine Light after Swap
Old Jul 30, 2002 | 01:27 PM
lonefuzzy79's Avatar
Default Check Engine Light after Swap
So I swapde in my 92 si SOHC engine. Dropped right in all hooked up and purrs like a big kitten (open headers still) but the check engine light is on. It has oil and water and all that and seems to run fine. The VTEC is not conected yet though. Do I need to reset the ECU or something Any ideas? Thanks
Old Jul 30, 2002 | 01:40 PM
4dohs4mohoes's Avatar
Default Re: Check Engine Light after Swap (lonefuzzy79)
well when i did my swap it did the same... but i found out that my O2 sensor is differant than what it needs, so check that out
Old Jul 30, 2002 | 02:19 PM
.nate's Avatar
Default Re: Check Engine Light after Swap (lilgreenhonda)
http://www.bseries.net/html/garage/engcode.php
Post up the code when you read it and we'll help you diagnose the problem from there...
ALSO: If vtec isnt hooked up, then it should throw a CEL.
Old Jul 30, 2002 | 03:43 PM
W.Zero's Avatar
if you hook up your vtec it should solve the problem or get the code
Old Jul 30, 2002 | 05:24 PM
RoaringTurtle's Avatar
New User
Default Re: Check Engine Light after Swap (N8)
is this true for sohc vtec motors as well?
i recently did a mini me
and i got a 96 ex ecu
plugged it in
but i get a cel code
i hooked the vtec up though
im pretty sure i got the wires right
but on the vtec pressure wire
there are 2 wires
one is ground correct and the other goes to the ecu right?
i thought my ecu was defunct
but it might be that i didnt hook up the vtec correctly
i checked the conections to the ecu with a meter
it has a good connection
but perhaps i hooked it up wrong
anyone know?
MR EF8
May 21, 2010 07:22 AM
Romeister21
Aug 29, 2008 01:03 PM
snoop_005
Jan 3, 2004 11:45 PM
boosted spoon
Jul 23, 2002 12:08 PM
milo
Dec 5, 2001 06:27 PM
