New OEM Exhaust
Old Nov 5, 2008 | 03:08 PM
Kashman90's Avatar
Default New OEM Exhaust Gaskets
So I am putting a new OEM factory replacement stock exhaust system on my 2001 Honda Prelude and every time I search up gaskets for my exhaust I only get results for these gaskets:
But I always thought you needed Gaskets that looked like this:
Which ones am I supposed to use?? I need to know which ones for the Intermediate pipe, front pipe, catalytic converter, and muffler pipe.
Modified by Kashman90 at 4:13 PM 11/5/2008
Old Nov 5, 2008 | 04:03 PM
ethereal2pt2's Avatar
Default Re: New OEM Exhaust Gaskets (Kashman90)
just get some liquid gasket and call it a day.
Old Nov 5, 2008 | 05:05 PM
LukieLuc's Avatar
Default Re: New OEM Exhaust Gaskets (ethereal2pt2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethereal2pt2 &raquo;</TD></TR><TR><TD CLASS="quote">just get some liquid gasket and call it a day. </TD></TR></TABLE>
wow!!! i never knew this existed it could've saved me sooo many hours of aggravation. The heat from the exhaust wont effect it?
Old Nov 5, 2008 | 05:35 PM
mattsnooz's Avatar
Default Re: New OEM Exhaust Gaskets (LukieLuc)
high temp rated ones should be okay. I used it, and haven't had any issues or odd smells even . It works on manifolds and block so should be okay??!
Old Nov 5, 2008 | 09:34 PM
never had problems with them. just be liberal with it when applying. make sure there's no gap.
Old Nov 5, 2008 | 09:37 PM
vinuneuro's Avatar
http://www.hondaautomotivepart...81%29
Old Nov 5, 2008 | 11:00 PM
TheJGB3's Avatar
Here is the parts exploded view
#14 is muffler gasket
18303-SM4-020 GASKET, MUFFLER $6.98
#16 is the gasket for the CAT to the extension pipe
18393-SH3-S00 GASKET, PRE CHAMBER (52.5MM-53.5MM) $7.32
#17 is the gasket for the downpipe/flexpipe to the CAT
18393-SS0-J30 GASKET, PRE CHAMBER (57.5MM-58.5MM) $7.24
All three of these gaskets are steel rings like the OP's pic and the SH and base model are the same part#s.
Modified by TheJGB3 at 12:12 AM 11/6/2008
Old Nov 6, 2008 | 09:48 AM
WayFastWhitey's Avatar
I work at a parts store and I have never seen anyone get good results from liquid gasket on an exhaust. The Goerlich exhaust numbers are 8702, 9080 and 9081. Save yourself some time and just get the correct gaskets. They are like $4 Each
Old Nov 6, 2008 | 12:01 PM
E-Money's Avatar
Default Re: New OEM Exhaust Gaskets (WayFastWhitey)
the metal O rings work just fine, i use rtv when i use mr gaskets
Old Nov 6, 2008 | 12:06 PM
AndyD's Avatar
Why do so many people insist on rigging up their cars?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WayFastWhitey &raquo;</TD></TR><TR><TD CLASS="quote">I work at a parts store and I have never seen anyone get good results from liquid gasket on an exhaust. The Goerlich exhaust numbers are 8702, 9080 and 9081. Save yourself some time and just get the correct gaskets. They are like $4 Each</TD></TR></TABLE>
The best way to go!
Old Nov 7, 2008 | 05:50 AM
TheJGB3's Avatar
Just re-use your old ones...FREE
Old Nov 7, 2008 | 06:07 PM
cwbb6's Avatar
i just replaced mine with those oem aluminum crusher type gaskets...definitely the way to go
Old Nov 8, 2008 | 02:52 AM
then you probably haven't seen many people use it, because i've probably done over 20 exhaust installations w/ these and never once had i experienced any leaking.
Old Nov 8, 2008 | 03:32 AM
mattsnooz's Avatar
I use liquid gasket sealent with metal gaskets. Its a staple with me. I guess I shouldn't recomend using it without the gaskets, (essentially between two flanges) because it is "rigging" and I'm usually not down with that. I have strict work ethics and apologize for suggesting that. It will work and do the trick though for a while but the gaskets should be bought and used as they were intended.
Old Nov 8, 2008 | 03:35 AM
mattsnooz's Avatar
Default Re: New OEM Exhaust Gaskets (mattsnooz)
Why don't you just buy the proper gaskets? I'm not saying the liquid gasket doesn't work, but if you do exhaust work, shouldn't you have a stockpile or a place where you can order the "proper" parts? ie. installations as per manual
drsab2000
Aug 26, 2015 03:34 AM
3Rd_gEn_LuDE
Feb 10, 2011 05:02 PM
PowerLeg
Jan 2, 2009 11:39 PM
Mushvroom
Sep 27, 2005 08:40 AM
ichikoo
Apr 25, 2005 11:33 PM
