getting out of the honda game everything needs to go
Old Nov 5, 2008 | 04:48 AM
96gsrhatch8230's Avatar
Default getting out of the honda game everything needs to go
im getting out of the game and have a ton of parts laying around in my garage and shed that neeed to go
heads
96 ls head
have cams,cam caps, valve cover, and sensors(no dizzy, manfold or tb)
$100
00 jdm b16 head
have valve cover, some sensors, vtec solenoid, cam caps, intake manifold, tb,(no dizzy) $300 needs line hone where cam goes
Blocks
00 jdm b16a block
vin 1014948
the block still has the crank in it never been taken out, oil pump, and water pump, the block is one of the cleanest blocks i have ever taken apart..
$200
95 jdm b18b bare block
vin 700688
the block is bare with main caps and bolts, i have a crank but it is taken out
$150
Pistons
jdm gsr pistons and rods$50
b16 pistons (pr3) on ls rods $200
ls rods$50
b16 rods$50
cams
ctr cams $300
2 sets of ls cams$100 ea
Cranks
b16 crank$100
ls crank$100
Trans
98 ls trans
trans has a slight grind in 3rd gear prob needs sinchros $300
jdm gsr trans/b16
its a b16 first second, third, gsr fourth, fifth and final
trans needs a casing not the bellhousing half the other side $300
turbo
turbonetics 60 trim turbo real nice turbo spools fast it needs new seals and a center housing which is cracked the housing is 150 from turbonetics
part # is 20375/60 $200
clutch
used act stage 2 with heavy duty pressure plate $50
ecus
0bd0 pr4 ecu 50 ea
0bd0 pm6 ecu
Random Parts
obd1 b series alternator 50
stock b series injectors and fuel rail $50
b series dohc vtec greddy timing belt used $75
gsr oil pump $75
b series tb
iac valve
datum 1 front and rear green tow hooks $75
stock internal dizzy coil
msd blaster coil
msd pro cap for gsr
msd boost timing master (5462) $100
misc sensors
del sol left tail light$50
del sol oem head lights with amber corners
yellow hid bulbs (no ballasts)
single jingle parts
stock mounts for eg
stock axles $75
t bracket
System parts
rockford 1 farat capassator
rockford 300 watt amp
powercoustic 10" sub in ported box
will update the list later that is just from the garage i still got a full shed of parts....
pics will be up shortly
most parts are best offer unless otherwise stated
located in north jersey
any questions call me
973 600 1988
mike
Old Nov 5, 2008 | 03:12 PM
i need to get rid of all this stuff i know someone needs some parts
Old Nov 5, 2008 | 03:52 PM
ITR.#1446's Avatar
Default Re: (96gsrhatch8230)
buy his parts!!!
Old Nov 5, 2008 | 03:55 PM
cuonglogan's Avatar
Default Re: (ITR.#1446)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">buy his parts!!!</TD></TR></TABLE>
no
Old Nov 5, 2008 | 05:29 PM
thanks brian i need to get rid of my honda junk yard lo l
Old Nov 6, 2008 | 04:11 AM
bump ttt
GETTING OUT OF THE HONDA GAME !!!
EVERYTHING MUST GO ;(
Old Nov 6, 2008 | 07:01 AM
SL0-hatch's Avatar
Default Re: getting out of the honda game everything needs to go (96gsrhatch8230)
bump for i wish i had money for those CTR cams!!!
Old Nov 6, 2008 | 09:19 AM
try to find some lol i need everything gone
Old Nov 6, 2008 | 12:20 PM
bumpp ttt
Old Nov 7, 2008 | 04:08 AM
bumpp still got everything
Old Nov 7, 2008 | 11:53 AM
bumppp
Old Nov 8, 2008 | 04:37 AM
morining bump
Old Nov 9, 2008 | 02:49 PM
bumpp
Old Nov 9, 2008 | 08:53 PM
ITR.#1446's Avatar
night bump for ya
Old Nov 10, 2008 | 04:24 AM
thanks bumpp
Old Nov 11, 2008 | 06:37 AM
bumpppp
Old Nov 13, 2008 | 04:06 AM
back to the top
Old Feb 24, 2009 | 06:12 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
are the injectors OBD1? If so, I do want.
Old Feb 24, 2009 | 06:21 AM
Sleeperzzz95's Avatar
Where were u when i needed a trans... N bought rims instead...
Old Feb 24, 2009 | 07:22 AM
blazinearth's Avatar
pmed
Old Feb 24, 2009 | 10:12 AM
killerpenguin21's Avatar
location?
Old Mar 17, 2009 | 03:26 AM
10secEK's Avatar
do you happen to have any parts for a 60-1 turbonetics small shaft need wheels they no longer make them..
hon2984
Apr 22, 2010 10:36 AM
ACrite3404
Mar 24, 2008 01:10 AM
blkteggy
Jul 31, 2007 06:38 PM
B20badboy
Mar 19, 2005 06:13 AM
AzN_Flava
Apr 17, 2002 06:17 PM
