how did you take your ARP head studs out?
Old Nov 4, 2008 | 04:49 PM
projectef's Avatar
Default how did you take your ARP head studs out?
sorry might sound like a dumb question, but how did you take your ARP head studs out of your block?
i tought it would not be a problem but, it is.
Old Nov 4, 2008 | 05:34 PM
ekb16's Avatar
alan wrench
Old Nov 4, 2008 | 05:38 PM
iwanttokillgod's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">alan wrench</TD></TR></TABLE>
or you can use two of the arp nuts put one upside down on first then screw the next one on as normal then use a wrench on the bottom one
Old Nov 4, 2008 | 05:51 PM
projectef's Avatar
i know that some has the alan wrench thing on the top of the stud, but mine dont have it. i used a vicegrip and still no luck
Old Nov 4, 2008 | 05:53 PM
projectef's Avatar
i'll try to that. one nut upside down and the other one normal.
thaks for the help guys
Old Nov 5, 2008 | 07:06 AM
projectTeG's Avatar
Default Re: (projectef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">i know that some has the alan wrench thing on the top of the stud, but mine dont have it. i used a vicegrip and still no luck</TD></TR></TABLE>
man no vice grips! youll damage the studs. do the lock nut trick it works.
Old Nov 6, 2008 | 10:28 PM
i drive a honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">i'll try to that. one nut upside down and the other one normal.
thaks for the help guys</TD></TR></TABLE>
you sure you did it right?
you loosen the bottom nut while the top nut holds it in place
Old Nov 7, 2008 | 05:09 AM
LA_HONDAS's Avatar
Default Re: (i drive a honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i drive a honda &raquo;</TD></TR><TR><TD CLASS="quote">
you loosen the bottom nut while the top nut holds it in place </TD></TR></TABLE>
what can i say
he said " I'LL TRY TO DO THAT" he just forgot to put "DO"
Old Nov 7, 2008 | 12:12 PM
94EG8's Avatar
Seagull Management
*Sigh* lock/tighten both nuts together, which actually involves turning one clockwise and one counter clockwise. then turn the bottom nut counter clockwise to remove the stud.
If you used vicegrips you probably already ruined the stud, you can try running a die over it to fix the threads if they don't look really bad.
Old Nov 7, 2008 | 12:15 PM
RotiEatter's Avatar
Ditto
Default Re: (94EG8)
True that. I learned that the hard way in my rookie days.
cbustuner
Jun 30, 2008 09:29 PM
NegativeXero
Nov 8, 2007 10:16 PM
freddysEF
May 23, 2007 01:26 PM
rice a roni
21
Apr 17, 2007 09:23 AM
Fatty_1775
Feb 9, 2006 11:02 AM
