*** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP ***
Old Nov 4, 2008 | 09:55 AM
jhonda239's Avatar
Default *** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP ***
For this project u r going to need:
- rtv (prefferably clear)
-a scuff pad
-spray paint
-an oven or heat gun
-basic hand tools
-little pry bar/screwdriver.
this is on a 96-98 headlight but its pretty much the same for all headlights.
heres the way it was wen i got the car.
there are 3 nuts/bolts for each headlight. the 3rd bolts are hidden underneath the fender.
rap the headlight in tin foil. preheat the oven to 225 degrees. put the headlight in the oven for 7-8 minutes. take the headlight out an try to pop out the clips around the outer edge first. take ur time prying the headlight apart with ur screwdriver. the old stuff should be gummyish.
scrape the old paint up to give the new paint something to adhere to. i did not relize the first time around that the relfector/blinker screws out from the back. so go ahead and do that be4 u scuff the old paint.
next: do a light coat of paint first. let dry 15-20 minutes(or go by directions on the spray can). do a medium second coat. no need for a third since the paint will not be enduring much. just make sure u cover everything on the second coat.
it is best to let dry overnight, but if u cant then let dry as long as possible.
next: put everything back together. put rtv in between the hedlight lense and the back of the headlight. it helps to get as much of the original glue out as possible.
let it sit for a while then put everything back together.
:D
and im not responsible any1 some how [freak]s sumthin up.
Modified by jhonda239 at 5:23 PM 11/6/2008
Old Nov 5, 2008 | 02:29 AM
jhonda239's Avatar
Default Re: *** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP *** (jhonda239)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhonda239 &raquo;</TD></TR><TR><TD CLASS="quote">http://honda-****.forumandco.c...3.htm
Old Nov 6, 2008 | 04:22 PM
jhonda239's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "96hatchy" &raquo;</TD></TR><TR><TD CLASS="quote">For this project u r going to need:
-a scuff pad
-spray paint
-basic hand tools
:D
and im not responsible any1 some how [freak]s sumthin up.</TD></TR></TABLE>
Old Nov 14, 2008 | 02:31 AM
jhonda239's Avatar
Old Nov 14, 2008 | 02:34 AM
Frost7177's Avatar
nice write up
Old Nov 15, 2008 | 02:24 PM
jhonda239's Avatar
Default Re: *** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP *** (Frost7177)
bout time. guess there are too many of the headlight write ups
Old Nov 15, 2008 | 02:26 PM
Mingo's Avatar
looks better then b4
Old Nov 16, 2008 | 03:47 PM
jhonda239's Avatar
Default Re: *** ANOTHER GREAT DIY PAINTED HEADLIGHT WRITE-UP *** (Mingo)
yea. i also restored the headlights with rubbing compound i just didnt take pics, because i didnt feel like buying all the sandpaper to do a really good job
Old Nov 16, 2008 | 05:55 PM
sintype's Avatar
cool.
NeverFinished
Jun 6, 2009 10:20 PM
Shaguar47
Mar 9, 2007 02:18 PM
KoreanVtecBoi
11
Mar 1, 2003 10:23 AM
BennySiR
10
Jun 1, 2002 04:11 PM
