Causes of Low Idle
Ever since I took off my TypeOne exhaust, my idle has been a little lower than normal. I used to be at ~800rpm with no accessories on. Now, my needle is ~400rpms. Can loose valves cause low idle?
EDIT - I've tried resetting my ECU and it hasn't done jack
[Modified by CPR, 3:17 PM 7/30/2002]
hmmmm...only occured after you took off the Type One?
I have a similar problem in my car after adjusting the valves. They were excessivly loose. Bringing them back down to spec, the car stalled a couple times. I think I may have had a hot idle problem... I may adjust the idle a bit, I'm not sure yet...
