Yellow light just came on
Old Nov 4, 2008 | 03:57 AM
LeonardDB's Avatar
Default Yellow light just came on
96 Accord SE, 165K miles, Does anybody know if this a problem or how to re-set? I'm not talking about the little maintenance indicator that you reset with your key. I am concerned whether the light indicates a problem that needs to be addressed. All the fluid levels are OK. The timing belt was changed 6 months ago. I did a few full message body searches and could not find this topic discussed.
Old Nov 4, 2008 | 05:32 AM
02 accord's Avatar
Default Re: Yellow light just came on (LeonardDB)
Your check engine light is on? Go to autozone and get the code pulled.
Old Nov 4, 2008 | 05:34 AM
FunnyVictor86's Avatar
don't forget to write the code down if you dont decide to get what you need to fix it then and there
Old Nov 4, 2008 | 07:53 AM
LeonardDB's Avatar
Default Re: (FunnyVictor86)
Thanks for the replies. I will go by Auto Zone to have the code read and then post the recommended fix.
Old Nov 5, 2008 | 06:29 AM
Duane_in_Japan's Avatar
Default Re: (LeonardDB)
Your initial post seemed to be talking about a MX reminder light and not a CEL, is this true, you seemed to want to turn it off by inserting your key into the reset keyhole, yes, but it would not turn off for you, is this the issue?
http://www.dhost.info/accordinfo/howto/cel.html
go to the very bottom of this page, is this what you are asking about?
haynesbc
Mar 2, 2008 12:22 PM
eL
Oct 25, 2003 05:25 AM
J T*
Feb 20, 2002 08:16 PM
