Overheating 1994 Civic LSi auto hatchback
Old Nov 4, 2008 | 02:02 AM
foxlinkinc's Avatar
Default Overheating 1994 Civic LSi auto hatchback
I have just taken on a 1994 LSi 2 door and when I got it I noticed someone had added a switch to the dashboard. When I enquired I was told that this was to turn on/off the radiator fan because it would not turn itself on. Okay, so, here's the problem, even with the fan going constantly the engine overheats after about 1/4 mile and just doing the 3 mile run to work down an open road involves 3 - 4 stops to allow the temp gauge to drop.
Any suggestions as to where to start with this would be great. I'm getting a replacement thermostat so I can disengage the remote switch they added to the fan but doubt if that will help since even withthe fan on she overheats.
Old Nov 4, 2008 | 04:34 PM
furiouscivic's Avatar
Default Re: Overheating 1994 Civic LSi auto hatchback (foxlinkinc)
you could also check you temp switch on the thermostat housing and the cooling fan relay which is in the under hood fuse box next to the battery. sounds like one of those two went bad so they bypassed with a switch. but the overheating is probably caused by the thermostat. just don't drive it too much with it overheating cause you'll blow the head gasket.
Old Nov 4, 2008 | 04:36 PM
drave's Avatar
Default Re: Overheating 1994 Civic LSi auto hatchback (furiouscivic)
Might be simple, but how is the coolant? Is there any in the reservoir tank?
LiL JoN
Nov 22, 2008 12:41 PM
kai-chun
12
Sep 8, 2006 03:20 PM
dog70
Jun 9, 2006 04:27 AM
wsiracerz
Jun 4, 2004 12:30 AM
ATS*Mark
Dec 9, 2003 11:08 PM
