why does my car redline at 5000 rpm
Old Nov 3, 2008 | 07:11 PM
ef8_crx's Avatar
Default why does my car redline at 5000 rpm
why does my car redline at 5000 rpm????
it was running fine then i took the tarnny of my car is was grinding 3rd so i got a b16 tranny and put it on now it redllines at 5000 rpm i dont now why would my tranny do that to my car i would think if it redlines at 5000 rpm it would be wiring prolbems i need help someone please
Old Nov 3, 2008 | 07:18 PM
em1_fox's Avatar
theres a lot of things dat can make ur car redline at 5k rpm..the one i can thinking at the top of my head is ecu..since ecu control how ur motor proforms
Old Nov 3, 2008 | 07:24 PM
ef8_crx's Avatar
Default Re: (em1_fox)
while why would my ecu got out....out of no where
Old Nov 3, 2008 | 07:34 PM
em1_fox's Avatar
dat i cant really tell how..but one time i was drive..and den i want to hit vtec..but i couldnt..n i was like wtf man..so i pulled over..look at my motor..it was fine..den looked at the ecu..the vtec wire was ripped..n i said how the hell did dat happened..
Old Nov 3, 2008 | 07:36 PM
ef8_crx's Avatar
ok then ill use another ecu i got to see if thats it
Old Nov 3, 2008 | 07:37 PM
raidacaipo's Avatar
Default Re: (ef8_crx)
ecu or wire issues.. maybe a wire is loose or something..
Old Nov 3, 2008 | 07:38 PM
em1_fox's Avatar
ya..ecu pretty much control the motor..but another thing..can be ur timing.wut tranny did u say u have
Old Nov 3, 2008 | 07:39 PM
ef8_crx's Avatar
another b16 that had a 3rd gear grind
Old Nov 3, 2008 | 07:43 PM
94c1v1cex's Avatar
wow you can change where the red mark on your tach is? thats the redline...
rev limiter is where your reving stops... redline is a physical mark on your tach
Old Nov 3, 2008 | 07:53 PM
em1_fox's Avatar
for the 3rd grinding..i wud seriously look for another tranny..
Old Nov 3, 2008 | 07:54 PM
joker4096's Avatar
check your speed sensor and see if that might be disconnected. also, are you throwing any CELs?
Old Nov 3, 2008 | 07:56 PM
jasony0630's Avatar
76.26.106.124
VTAK is hitting way too hard for your stock computer to handle!
You need to put a s2000 ecu to cope with that!
I don't know wtf you did to make your VTAK hit so hard that it rev limits, but you must be a [freak]ing god!!!!!
Old Nov 4, 2008 | 01:43 AM
ef8_crx's Avatar
Default Re: (jasony0630)
ok what ever but i changed ecus and its running fine it cause i had a p28 with s100 tuned for my other setup
Old Nov 13, 2008 | 01:07 PM
joker4096's Avatar
cool you found the problem
saveacivic
Feb 19, 2011 06:15 AM
gottagofaster
Oct 23, 2005 11:23 AM
love2xlr8integra
Aug 23, 2004 05:51 AM
T--Rex
Jul 18, 2004 09:37 AM
crashtest Sonny
34
Dec 15, 2002 05:57 PM
