Strange Problem when re-fueling
Old Nov 3, 2008 | 05:11 PM
sp00nek9's Avatar
Default Strange Problem when re-fueling
as of late every time i fill up my car with gas, then start the car to leave... it takes at least 3 times to get the car started and i have to feather the gas to keep it running. but after about 60 sec of this it runs perfect idle's fine etc etc. this problem is only when i fill up. it dosent do this any other time. ive tried about 10 diffrent gas stations. filled from dead empty, and also from 1/8 of a tank and 1/2 a tank and still same issue.
set up is as follows
00 hatch
ls vtec
stock fuel system
odb1 p28 on chrome
and i always use 93 0ctane.
any help/input would be greatly appreicated. thanks
Old Nov 3, 2008 | 05:17 PM
obuhmyuh's Avatar
Default Re: Strange Problem when re-fueling (sp00nek9)
does the fuel pump sound normal when it primes after you fill up?
Old Nov 3, 2008 | 05:19 PM
sp00nek9's Avatar
Default Re: Strange Problem when re-fueling (obuhmyuh)
yeah it seems to function normally, bc any other time it fires right up and runs perfect. im stumped
Old Nov 3, 2008 | 07:16 PM
srmofo's Avatar
be;ieve it or not my eg did that same thing until I replaced the main relay....it seemed like it would only act up at the gas station
Old Nov 3, 2008 | 07:20 PM
DCSportEJ1Civic's Avatar
are you pumping to the next dollar after it clicks? or do you let it click off once and stop filling? there is a reason it stops when it does. you could be filling your charcoal canister with fuel. i dont think that would cause your problem but its a start.
Old Nov 3, 2008 | 08:06 PM
sp00nek9's Avatar
Default Re: Strange Problem when re-fueling (DCSportEJ1Civic)
thanks for your input guys. any other suggestions?
OldSkoolEskimo
Honda Civic (2001 - 2005)
Jul 31, 2006 07:47 PM
igo4bmx
May 20, 2005 12:58 PM
silverb18
Apr 24, 2005 06:31 PM
pr0digy1
May 8, 2002 09:08 AM
itr0032
Jun 26, 2001 12:33 PM
