H2B CRX no spark?
Old Nov 3, 2008 | 11:59 AM
AllMtrRex's Avatar
Default H2B CRX no spark?
Posting for a friend.
Jdm obd1 h22 (from hmotorsonline)
1988 Crx HF
The Engine is turning over fine. I actually heard it over the phone.
Fuel pump is coming on and priming.
Car is using rywire 0bd0 to Obd1 ecu jumper harness with chipped P28
note: Also has used stock p28, to see if its the ecu. And disconnected the jumper and tried a PM6 obd0 ecu to see if it was the jumper.
The ground is on the thermostat housing correctly.
The distributor is the Hmotors one and doesn't have a spare.
Also all fuses in cabin and engine bay are good
Im trying to help, over the phone and that can be a pain.
Problem: no spark on # 1 spark plug?
The only thing I could think off after I confirmed all the above was Bad Coil, or Bad Wires. The are both from Hmotors and Ive never heard of any faulty Dizzys from them?
Any advice could help. He does have a daily, but small bugs like this are irritating.
Modified by AllMtrRex at 1:07 PM 11/3/2008
Old Nov 3, 2008 | 12:46 PM
LA_HONDAS's Avatar
Default Re: H2B CRX no spark? (AllMtrRex)
or a bad icm
Old Nov 3, 2008 | 01:32 PM
AllMtrRex's Avatar
Default Re: H2B CRX no spark? (LA_HONDAS)
by the looks of it, would be cheaper to buy a used working dizzy than a new icm
Old Nov 3, 2008 | 02:10 PM
LA_HONDAS's Avatar
take one out of a d or b-series dizzy and try it
it should bolt up
Old Nov 3, 2008 | 02:13 PM
AllMtrRex's Avatar
worth a try...guess he'll check that after the coil..
Old Nov 6, 2008 | 04:55 PM
jakeiscool's Avatar
Banned
check grounds before you go crazy.
Old Nov 7, 2008 | 05:26 AM
AllMtrRex's Avatar
Default Re: H2B CRX no spark? (jakeiscool)
it was a bad coil from hmotors...replaced with b series. and it started right up. coil actually tested ok, with a multimeter....hmm...
Old Nov 7, 2008 | 01:55 PM
jakeiscool's Avatar
Banned
you sure it wasnt some of the contacts then?
Old Nov 8, 2008 | 11:08 AM
AllMtrRex's Avatar
couldnt tell ya. Just know the coil tested good with the multimeter and we forgot about it.....then just decided to try another coil after a few days and it started right up
CrazyE
Feb 11, 2015 08:08 AM
yanksox
Jul 3, 2007 02:54 PM
menappi
Apr 23, 2006 11:06 PM
McDade
Sep 12, 2003 12:39 PM
