ctr headlight clensing.
Old Nov 3, 2008 | 12:46 AM
Mfoehrkolb's Avatar
Default ctr headlight clensing.
<FONT SIZE="4">BEFORE</FONT>
<u>RIGHT HEADLIGHT</u>
<u>LEFT HEADLIGHT</u>
<FONT SIZE="4">AFTER</FONT>
Modified by Mfoehrkolb at 1:59 PM 11/3/2008
Old Nov 3, 2008 | 03:13 AM
nix94delsol's Avatar
Default Re: ctr headlight clensing. (Mfoehrkolb)
ofmgwtfbrb!
wheres the tech yo?
Old Nov 3, 2008 | 04:34 AM
alphalanos's Avatar
Default Re: ctr headlight clensing. (nix94delsol)
whats the point.
Old Nov 3, 2008 | 05:15 AM
EJ8freek's Avatar
Where's the write-up?
Old Nov 3, 2008 | 10:00 AM
Mfoehrkolb's Avatar
Pictures Updated.
Old Nov 3, 2008 | 10:55 AM
civicjoe's Avatar
Default Re: (Mfoehrkolb)
It would be great if there was a write up to go along with the pics. Next spring I am looking to clean my headlights up.
Old Nov 3, 2008 | 11:04 AM
Matt.D87's Avatar
Wooh what did you use to get that?
Old Nov 3, 2008 | 11:27 AM
SpeedoKing's Avatar
Default Re: (Matt.D87)
where is the write up man ...but props these are the best results i have seen so far for cleaning headlights.
Old Nov 3, 2008 | 11:52 AM
The Collin's Avatar
Yay.
Pictures of clean headlights.
Brilliant!
Old Nov 3, 2008 | 12:46 PM
nbcivic's Avatar
did you want to tell us how you did it/how long it lasted?
Old Nov 3, 2008 | 02:47 PM
dacuslil's Avatar
you dont have to remove the lights from then car most of thehaze is all outside just start with 1500 grit sand paper and da scuff real good go to 3000 grit wet sand the buff with rubbing compound looks brand new
Old Nov 3, 2008 | 02:53 PM
Partizan's Avatar
in for write up
Old Nov 3, 2008 | 04:15 PM
joker4096's Avatar
very nice job, but where the hell is the write up, what products did you use or else this thread will be a complete FAIL
Old Nov 3, 2008 | 05:01 PM
Mfoehrkolb's Avatar
These were a pair i just did for a customer. It isn't a DIY, just needed to post the pictures up for him so he could see how they came out.
If you look @ my sig. Retrofitting is my game.
Old Nov 3, 2008 | 05:34 PM
FRKWOO's Avatar
i would also be interested in doing the same. can u do a write up?
Old Nov 3, 2008 | 06:35 PM
BlueIntegraBoy's Avatar
Default Re: (FRKWOO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRKWOO &raquo;</TD></TR><TR><TD CLASS="quote">i would also be interested in doing the same. can u do a write up?</TD></TR></TABLE>
Start wetsanding with 1000 grit, then 1500, and finally 2000. Finish off with a buffing of a rubbing compound.
Old Nov 3, 2008 | 07:35 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">These were a pair i just did for a customer. It isn't a DIY, just needed to post the pictures up for him so he could see how they came out.
If you look @ my sig. Retrofitting is my game.</TD></TR></TABLE>
If you just wanted to show him you could have emailed him or PMed him.
Old Nov 3, 2008 | 08:03 PM
ke98248's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Start wetsanding with 1000 grit, then 1500, and finally 2000. Finish off with a buffing of a rubbing compound.</TD></TR></TABLE>
Word... 1,000 grit will take off a lot of the hazing creating by UV rays from the sun.. 1,500 grit will help take down the scratches created by the 1,000 grit sandpaper. Hitting it with 2,000 grit sandpaper will help remove most major, visible scratches.. Using 3,000 grit is totally pointless and a waste of time. Make sure you wet-sand. Use a soft dura-block, wrap the sandpaper around it, and have a spray bottle filled with water available. You wanna keep the headlight and the paper wet at all times...
A buffing compound like Meguiars Diamond Cut 2.0 works great! Be careful: you can burn the plastic, keep the RPM's at about 1,000 with light/medium pressure if you have a nice adjustable speed polisher, and keep the headlight lens relatively 'wet' with compound.
Old Nov 3, 2008 | 09:23 PM
hgem1si's Avatar
Default Re: (ke98248)
Hahaha, I often make threads to show people things.
Old Nov 4, 2008 | 04:53 PM
dacuslil's Avatar
i have done prob 10 sets of headlights in past year always started with 1500 and then 3000 grit wet then buffed always turn out great
RAY_DA9
Dec 6, 2010 04:04 PM
Iloveyourhonda92
Apr 6, 2010 04:57 PM
alphanumeric
Dec 3, 2005 09:03 PM
DagYo!
Mar 31, 2004 03:58 PM
ek9vboi
Jul 2, 2003 04:30 PM
