seat swaps (searched but no luck)
you might be able to swap the cushions over to your frames.... I've got a friend who put S2K's into his EG hatch by this method and it worked fine, the cushions bolt pattern was the same on both frames so he trashed the S2K frames and his stock cushions.
Otherwise you'll need either a drill some bits and threaded clips or a welder and chisel and some patience! It's not too bad though to bolt them down in another car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smcowman »</TD></TR><TR><TD CLASS="quote">what about a pair of integra seats? are the bracjets the same or would i need new?</TD></TR></TABLE>
If you can get ahold of some nice GSR seats they swap right in and are a major upgrade from stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smcowman »</TD></TR><TR><TD CLASS="quote">last question is this...are the DA seat rails the same as in the DC integras? cuz if they are then they should bolt right up</TD></TR></TABLE>
nope, not the same.
nope, not the same.
BB4lude
Apr 30, 2008 10:30 AM
Hondasaurs
Jan 31, 2003 08:05 AM
