Need help ASAP!! obd0 motor into obd2 car..
Old Nov 2, 2008 | 05:33 AM
EGSR-T's Avatar
Default Need help ASAP!! obd0 motor into obd2 car..
K, long story short.. Picked up a 98 LS with a blown motor, got a GREAT, and I mean GREAT deal on an obd0 b18a1 with shotpeened rods and pr3 pistons, I didn't want an obd0 motor but for the price I couldn't pass it up.. I've noticed I've got a huge issue here, atleast I think it's a huge issue.. Was wondering if anyone knew the answer to this..
The obd2 motor has a plug by the crank that the obd0 motor doesn't have (think it's like a crankshaft position sensor or something, not sure though) I know if I run the motor without it the car is going to throw a code, not sure how it's going to run, probably horrible.
Is there any way to bypass this, I know I'm not the first guy to put an obd0 motor into an obd2 car, so someone has to chime in on this.. I'm half tempted to buy an obd2-obd1 conversion harness and obd1 LS ecu, but wanted to know if there was ANY other way around this..
Old Nov 2, 2008 | 06:24 AM
slaminsam's Avatar
Default Re: Need help ASAP!! obd0 motor into obd2 car.. (EGSR-T)
http://technet.ff-squad.com/ckftrick.htm
https://honda-tech.com/zerothread?id=1029958
There is the bypass trick...
Old Nov 2, 2008 | 12:44 PM
EGSR-T's Avatar
Default Re: Need help ASAP!! obd0 motor into obd2 car.. (slaminsam)
You're a lifesaver now, I was about to order a conversion harness, and obd1 p75 just to get the car running correctly, glad I just saved myself $150.
Thanks again!
hate!
10
Apr 30, 2010 09:02 AM
VtecFreePrelude
Mar 8, 2010 01:22 PM
delslow!
Sep 30, 2009 09:09 AM
Jhonny Ricer
May 28, 2007 12:02 AM
BigPlansNoMoney
Nov 15, 2004 08:02 AM
