rookie supension question
They'll work, they need to have a 1/4-1/2" spacer in between. And are in fact the same struts for both gen civic's. just the ek ones come with lil washers.
Oem rear struts are different. aftermarket Tokico's are the same.
ok so if i understand they fit back and front but need in the front a spacer. how do i know the size of the spacer is good enough and where to put the spacer . thanks
No, you don't understand:
The fronts will fit A-OK.
The rears require spacers inside the shock fork on both sides of the LCA bushing. It takes two 1/4" spacers for each side (included with the Tokico shocks new). Call Tokico and order some, or just go to the hardware store and pick up a pack of grade 8 washers.
ok and before doiing the shocks and spring install can i get info exactly on what to put. like i saw on a post here some stuff about lca ajustable camber and all kind of suspension stuff. i have 2 front upper ball joint to change to is there after market one. just give me picture or past post or website on this 411 suspension info please
sorry about my noobeness on suspension
if you wanna fix camber in the rear, do not buy the shortened or camber lca's. they F'ck up your toe big time. and requiring you to buy aftermarket toe adjusters.
and please stop calling them shocks. most hondas have struts, not shocks.
NosCivic01
Aug 27, 2005 06:46 AM
