If i put my stock cams back in do i need a re-tune????
Old Nov 1, 2008 | 04:06 PM
stonet149's Avatar
Default If i put my stock cams back in do i need a re-tune????
Old Nov 1, 2008 | 04:18 PM
z6hatchboy's Avatar
it'll need a stock tune. You may can drive it but it wont run good and im not sure if it would detonate
Old Nov 1, 2008 | 04:27 PM
stonet149's Avatar
Default Re: (z6hatchboy)
Old Nov 1, 2008 | 04:34 PM
z6hatchboy's Avatar
the difference in boost and n/a cams is valve overlap, which affects how much vaccuum you'll have, scavenging affect, and a few others. The main thing id be worried about is the timing of a stage 4 cam going back to a stock one
Old Nov 1, 2008 | 04:38 PM
stonet149's Avatar
Old Nov 1, 2008 | 04:49 PM
z6hatchboy's Avatar
When a cars tuned theres also igntion adjustments done in the ecu just a fuel adjustment and thats something you cant change by changing the initial ignition timing at the dizzy or cam gear (if applicable). The other cam differences as the duration of the lift and maybe even the lift its self, try a search somewhere. I can only remember some of it lol
Old Nov 1, 2008 | 06:10 PM
stonet149's Avatar
emd513
Feb 20, 2012 04:56 PM
PreStaged12s
15
Mar 21, 2009 10:55 AM
cubancrx
Apr 16, 2004 07:49 PM
TurBoTeG
Aug 15, 2002 10:33 AM
civicmark
Jun 26, 2002 09:39 PM
