D15b vtec: Vtec Solenoid???
A buddy told me that if I run a p28 ecu with the jdm d15b vtec that i would have to switch the vtec solenoid to a usdm vtec solenoid or else I would throw a code for the vtec oil pressure sensor becuase apparently the jdm d15b vtec solenoid only has 2 wires and doesnt pick up that sensor.
Does that sound right to anyone? Can someone please clear this up for me!
Well that depends. If i understand you correctly you want to run a p28 on a JDM D15B Vtec engine. Some JDM Solenoids dont have a OIL PRessure sensor, thus a p28 requieres one. So that would depend on wether or not your solenoid has a OIL Pressure plug or not.
Someone correct me if im wrong.
you can ground out that sensor because i had that same question, and this is what a guy on my local forum said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guy from Dallasimports.net »</TD></TR><TR><TD CLASS="quote">ground it out off the ecu, and you don't even need it as JDM engines don't use it...but its nice to have it just keeps vtec from engaging with less the adequate oil pressure. but grounding the sensor out fools the ECU into thinking its at a constant high oil pressure...the idiot light for the oil pressure wont be affected as the ecu uses a DIFF oil pressure sending unit to monitor engine oil pressure.
just fyi, don't ground the wire off the sensor, in other words
[ECU]--------(to sensor)-->------------//ground |-------<sensor></TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatpride111 »</TD></TR><TR><TD CLASS="quote">you can ground out that sensor because i had that same question, and this is what a guy on my local forum said:
Well to me thats just to much BULL. Just get a sensor with a oil pressure sensor and call it a day
Im **** with my cars..... I dont like doing MICKEY MOUSES on my car.
if it works, then it works. im not recomending it, nor saying its a bad idea, but what do you mean by this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote">
have you done the swap yet? try the ECU out, and if its throwing code 21, then its searching for the Vtec Pressure switch, which is (i belive) 2 wires coming under the Vtec Solenoid which i think is 1 wire.
Here is a pic of a jdm one
Here is a pic USDM
Notice how the USDM one has this GREEN SENSOR thing ?? Thats the Oil Pressure Sensor that a p28 ecu will look for
Here is a pic USDM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote">Here is a pic of a jdm one
Here is a pic USDM
Notice how the USDM one has this GREEN SENSOR thing ?? Thats the Oil Pressure Sensor that a p28 ecu will look for</TD></TR></TABLE>
OH, thats what you were talking about. my bad, man, i kept thinking you were talking about the solenoid
in that case, if the USDM one fits, which i dont see why it wouldnt, then yeah, just swap it out. a pressure switch for my gsr ran me about 63 bucks so its not that bad
Here is a pic USDM
That's retarted.
Vtec will kick in like 10 times harder and take like 1 second off your quarter mile time if you just take the VTEC solenoid off.
The oil pressure coming from the pistons is higher than the VTEC solenoid oil pressure.
Therefore, once that pressure goes into your head, you'll have VTAK. Which is NOT to be mistaken with VTEC, because VTEC is [freak]ing gay and weak, whereas VTAK actually does something.
naw man what you gotta do is run that'n there green wire back into t'other one man it makes the vtec stay on all the time and it spins the tires straight off the line up until you ****** 4th gear but it still barks it a little bit mane.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 »</TD></TR><TR><TD CLASS="quote">That's retarted.
Therefore, once that pressure goes into your head, you'll have VTAK. Which is NOT to be mistaken with VTEC, because VTEC is [freak]ing gay and weak, whereas VTAK actually does something.</TD></TR></TABLE>
Wow.... Simply WOW. 715 posts and still acting like a Dumb@ss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 »</TD></TR><TR><TD CLASS="quote">715 posts and still rockin.
Since I'm the dumbass that would believe something like that.</TD></TR></TABLE>
fail
fail
Marktwo
12
Jun 28, 2004 11:27 AM
0ptimus prime
Jun 5, 2004 06:28 AM
Apex i ITR
Oct 21, 2001 05:00 PM
