Just got header need help!!!
Old Oct 31, 2008 | 09:49 PM
reyrey2006's Avatar
Default Just got header need help!!!
Ok so I have a 1998 Honda Civic ex with a d16y8 sohc vtec I just got a used header. The o2 sensor on my stock manifold is about mid way down the manifold.
On the new header it is near the connector to the cat is this header for an obd1 car or older??
What are my choices??
Old Oct 31, 2008 | 09:51 PM
slo_hatch's Avatar
Default Re: Just got header need help!!! (reyrey2006)
obd1 only have one oxygen sensor...your car should have 2. one in the exhaust manifold and one before the cat. (the pic is right for an obd2 car).
Old Oct 31, 2008 | 09:58 PM
reyrey2006's Avatar
Default Re: Just got header need help!!! (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">obd1 only have 1 oxygen sensor...so that is obd2. if it is aftermarket you will have to extend the wires. let me guess...its an eBay special right?? </TD></TR></TABLE>
Nah, it's a carb legal holley airmass header.
The wires are already extended but they have different connectors and they have one o2 sensor
Old Oct 31, 2008 | 10:04 PM
slo_hatch's Avatar
thats strange...it prolly does away with one of the o2 sensors or it just makes an obd1 car look better by moving the sensor underneath the car. im not sure on your options...i would think that you could maybe drill a hole around where your upstream one goes and thread it and put it in but im not sure on what would happen with your codes and what not.
Old Oct 31, 2008 | 10:10 PM
reyrey2006's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">thats strange...it prolly does away with one of the o2 sensors or it just makes an obd1 car look better by moving the sensor underneath the car. im not sure on your options...i would think that you could maybe drill a hole around where your upstream one goes and thread it and put it in but im not sure on what would happen with your codes and what not. </TD></TR></TABLE>
That's what I was thinking just drilling a hole a threading it but I'm going to install it tomorrow so I guess I'll find out
Thanks for your help
Old Oct 31, 2008 | 10:16 PM
slo_hatch's Avatar
no prob. BUMP!!! maybe someone else can give you some answers...let me know how everything turns out.
Old Oct 31, 2008 | 10:20 PM
reyrey2006's Avatar
4 sure
Old Nov 1, 2008 | 05:06 AM
slacks's Avatar
just reuse the same 02 sensor and extend the wire to the harness.
Old Nov 1, 2008 | 05:46 AM
davefromPA's Avatar
Default Re: Just got header need help!!! (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">just reuse the same 02 sensor and extend the wire to the harness.</TD></TR></TABLE>
do this. OBD2 cars have two o2 sensors, one before the cat and one after it. that o2 sensor that is plugged in is for an obd1 cx do to it having only one wire. take that one out, put yours in and keep the other o2 sensor you have plugged in behind the cat. its simple man
saxyman2k
Oct 22, 2004 08:38 AM
Ionix
Sep 30, 2004 07:40 AM
projektCRX
Aug 28, 2004 10:53 AM
tyflip2
Jun 26, 2004 03:22 PM
tuan...
Feb 12, 2004 09:37 AM
