Just got header need help!!!
Re: Just got header need help!!! (reyrey2006)
obd1 only have one oxygen sensor...your car should have 2. one in the exhaust manifold and one before the cat. (the pic is right for an obd2 car).
Re: Just got header need help!!! (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch »</TD></TR><TR><TD CLASS="quote">obd1 only have 1 oxygen sensor...so that is obd2. if it is aftermarket you will have to extend the wires. let me guess...its an eBay special right?? </TD></TR></TABLE>
Nah, it's a carb legal holley airmass header.
The wires are already extended but they have different connectors and they have one o2 sensor
thats strange...it prolly does away with one of the o2 sensors or it just makes an obd1 car look better by moving the sensor underneath the car. im not sure on your options...i would think that you could maybe drill a hole around where your upstream one goes and thread it and put it in but im not sure on what would happen with your codes and what not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch »</TD></TR><TR><TD CLASS="quote">thats strange...it prolly does away with one of the o2 sensors or it just makes an obd1 car look better by moving the sensor underneath the car. im not sure on your options...i would think that you could maybe drill a hole around where your upstream one goes and thread it and put it in but im not sure on what would happen with your codes and what not. </TD></TR></TABLE>
That's what I was thinking just drilling a hole a threading it but I'm going to install it tomorrow so I guess I'll find out
Thanks for your help
Re: Just got header need help!!! (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">just reuse the same 02 sensor and extend the wire to the harness.</TD></TR></TABLE>
do this. OBD2 cars have two o2 sensors, one before the cat and one after it. that o2 sensor that is plugged in is for an obd1 cx do to it having only one wire. take that one out, put yours in and keep the other o2 sensor you have plugged in behind the cat. its simple man
Ionix
09-30-2004 07:40 AM
