BUILT LS.V PART OUT....
built long block.. 250 + hp 150 miles. ONLY TOOK OUT CUZ TRANNY WENT BAD.
3,000 OBO. complete long block.
<U>BLOCK</U>
darton sleeve integra block. b18b1.
brand new OEM 85.mm head gasket
wiseco 13.1 pistons.
eagle rods
arp rod bolts
arp head studs.
brand new OEM type r water pump
brean new oem itr timing belt
Balanced crank
ACL Race bearings
ACL Main bearing
Head
dtr big port.
3 angle valve job
supertech valve guides
supertech flat valve's
supertech Springs
buddyclub stage 3 cams
buddyclub cam gears
http://www.flickr.com/photos/justjoey06/2882997577/
http://www.flickr.com/photos/justjoey06/2455708998/http://www.flickr.com/photos/justjoey06/2454867613/ <U></U>
Modified by Your Name at 7:08 PM 11/1/2008
Modified by Your Name at 12:19 PM 11/2/2008
Modified by Your Name at 12:21 PM 11/2/2008
<U>BLOCK</U>
eagle rods
arp rod bolts
arp head studs.
Balanced crank
ACL Race bearings
ACL Main bearing
Head
dtr big port.
3 angle valve job
supertech Springs
buddyclub cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Your Name »</TD></TR><TR><TD CLASS="quote">
