4-1 header subframe clearence G2 Teg?
Ok so as far as i knew and have been told a 4-1 header will not clear the factory subframe on a g2 integra. Come janurary ill be starting my long over due body work and re-doing my exhasut to help my 13:0.1 Ls/V breath better. I worked on a G2 today that had a Dc JDM 4-1 with the factory subframe untouched!!! How did this guy get it to fit in there with out rubbing? I have an idea of taking the subframe down and then installing it that way but it doesnt hit the saubframe at all?Anyone else running a 4-1 with factory subframe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI »</TD></TR><TR><TD CLASS="quote">Ok so as far as i knew and have been told a 4-1 header will not clear the factory subframe on a g2 integra. Come janurary ill be starting my long over due body work and re-doing my exhasut to help my 13:0.1 Ls/V breath better. I worked on a G2 today that had a Dc JDM 4-1 with the factory subframe untouched!!! How did this guy get it to fit in there with out rubbing? I have an idea of taking the subframe down and then installing it that way but it doesnt hit the saubframe at all?Anyone else running a 4-1 with factory subframe?</TD></TR></TABLE>
when you find out you let me no becuase im trying to figure out the same thing!!
I banged my front cross member. Ground clearance is horrible and I'm going with an ESP traction bar instead.
I wouldn't bother with the header, for the extra 1-4hp... I'd rather have ground clearance.
THMotorsports
Sep 21, 2004 03:11 AM
