Bad TPS?
Old Oct 30, 2008 | 06:17 PM
jdmkid_82's Avatar
Default Bad TPS?
is it possible for a TPS to be going out or bad w/ out setting out throwing a code?, and what can you expect from a bad tps
Old Oct 30, 2008 | 07:26 PM
SlowCGP_EJ8's Avatar
Default Re: Bad TPS? (jdmkid_82)
When my TPS went bad, It did not throw a code. It also wouldn't allow me to rev over 3k rpm.
Old Oct 30, 2008 | 07:27 PM
HuntsTURB0civic's Avatar
i've never seen one go bad now that i think of it but usually they break during an engine install etc... try unpluging it and see if it makes any difference.. i know that when they are not calibrated correctly then it will run funky.. mine was off and it only ran until about 75% throttle and bogged terribly at full throttle.. then i possitioned it correctly and it was fixed..
there is a CEL code for a TPS but it didnt throw the code when mine was in the wrong position..
i would assume that it wouldnt even start
Old Oct 30, 2008 | 07:53 PM
mikehawk's Avatar
Default Re: Bad TPS? (HuntsTURB0civic)
im throwing a tps code and my car drives fine .. just when the engine is cold it wont idle .. esp when its cold it will shut off if I dont give it a little gas.. like litterally when you start it the tach doesnt budge lol
Old Oct 31, 2008 | 12:11 AM
jdmkid_82's Avatar
is there a right up to adjust it? when its out of wack did the car feel like its constantly climbing a hill>?
Jej2386
Feb 18, 2010 11:27 AM
boostedb20z
Jun 25, 2009 12:11 PM
Juan_Mitosis
Feb 4, 2008 04:39 PM
Walshie
11
Dec 1, 2006 01:42 PM
ludacole
Aug 13, 2005 11:59 PM
