99 EM1 "alternator SP Sensor" fuse keeps blowing. Immediate help needed!
I have had the alternator and battery both checked and they are both good, it's a 7.5 fuse and it blows almost immediately after I start the car. I'm really confused as to why it's doing this when both of the charging systems are good. The car randomly lose power (cd player, tach, lights dim, idles low, etc) while I'm driving and only if I replace the fuse in time will the car start again. I usjay have to end up jumping it because the car ends up running on battery power only.
I've had a few local mechanics look at it, and no one cH seem to pinpoint the problem.
Does anyone have any idea as to what this could be? It's my DD, so I'd like to have this up and running correctly asap. Thanks in advance.
is there any way that your electrical system has a un natural amount of load on it? and have your REALLY checked your grounds (take them off and use a metal brush to make sure its good contact?)
Thanks for the quick reply, but nope, I don't have anything extra besides just a normal CD player. Unfortunately, I'm posting this from my phone because my car just blew the fuse and died again before I could see it. I use those "Smart glow" fuses that light up when they blow... this one didn't light up haha. Wonderful.
I don't think I've checked all of the grounds because I'm not sure that I know where all of them are located... care to point them out for me?
Sorry for the noob question, but thanks for your help homie.
were you working on your car recently?
happened to me before. problem was one of the O2 sensor wires on the cat was touching the body of the car.
The only thing I've done recently (before pulling the apt and battery) as putting on a different intercooler.
u hit a wire on ur system somewhere... happened to me i replaced alternator and battery and kept blowing the fuse. i broke a wire on my o2 sensor on a rock or sumthin and it makes the fuse keep blowing which basically makes ur car not recognise ur alternator. find the wire. look in areas u worked on and other areas like o2 where u could have hit sumthin in the road. mine took me over a month to figure it out. i had my tuner look up a wire diagram and immediatly he said look under ur car at ur o2 sensor and bam fixed the wire and replaced the fuse and there u go good as new... hope u find it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b20vtecoupe »</TD></TR><TR><TD CLASS="quote">u hit a wire on ur system somewhere... happened to me i replaced alternator and battery and kept blowing the fuse. i broke a wire on my o2 sensor on a rock or sumthin and it makes the fuse keep blowing which basically makes ur car not recognise ur alternator. find the wire. look in areas u worked on and other areas like o2 where u could have hit sumthin in the road. mine took me over a month to figure it out. i had my tuner look up a wire diagram and immediatly he said look under ur car at ur o2 sensor and bam fixed the wire and replaced the fuse and there u go good as new... hope u find it
Ah, so you're saying I should check around my o2 sensor first? Well, once I get outta class, that'll be the first thing I check. Thanks man.
</TD></TR></TABLE>Ah, so you're saying I should check around my o2 sensor first? Well, once I get outta class, that'll be the first thing I check. Thanks man.
yea look for a break or even a tiny slpice mine i couldnt even tell til i was looking rite at it i think i snagged a rock or sumthin. but im obd1 now and it was on my secondary o2 so all i had to do was just unplug it. cause its all connected on the same circuit so any rips in a wire will cause this.
There is a service bulletin from Honda about this very problem.
The bulletin details a specific area of the engine harness that gets rubbed through against the intake manifold support bracket. This affect the alternator output, vehicle speed sensor, oxygen sensors, throws an ELD code sometimes, etc.
Bulletin number is:
99-029
I'm trying to find a picture that shows/details the actual bulletin as it is from Honda. I've got it here in front of me on All Data but there is no way to save the pic and host/post it.
A Google search of "Honda service bulletin 99-029" yielded some .pdf files.
Bulletin number is:
99-029
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">There is a service bulletin from Honda about this very problem.
Bulletin number is:
99-029
Oh wow! Thank you. My speedometer doesn't work and I've been throwing the ECU code for it for about 2 weeks. I can't go over 4.5k rpms before the CEL comes on or else I 2 step.. even when I'm driving on the expressway.
So what do you suggest? Check the engine harness by the intake manifold? See if anything is spliced or rubbed out or something?
Bulletin number is:
99-029
I just dealt with this very same problem last week on my 99 si. Replaced alt and battery and a few hundred dollars later found out that my secondary o2 sensor was rubbin on heat shield and shorting out causing the fuse to pop. Check o2 sensors as they are on the same circuit as alt and speed sensor. Hope this helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bargs2006 »</TD></TR><TR><TD CLASS="quote">I just dealt with this very same problem last week on my 99 si. Replaced alt and battery and a few hundred dollars later found out that my secondary o2 sensor was rubbin on heat shield and shorting out causing the fuse to pop. Check o2 sensors as they are on the same circuit as alt and speed sensor. Hope this helps!</TD></TR></TABLE>
Thanks dude, I'll definitely check that out in the morning.
Your engine harness is rubbing against the bracket that holds the intake manifold up and its grounding out. You have to cut the wire tie to free it and then wrap electrical tape on the wires to cover them back up. You can see the harness if you look back towards the t bracket.
dig up old thread lol
dont know if you guys found the source of your problem but ive just come accross it too
and i believe mine is caused by the location of the o2 sensor on my aftermarket headers. its been rubbing against the rear engine mount and finally tore 3 wires
ive just disconnected it temporarily...
