tranny Q.??
well i been reading a few threads about tranny fluid and i wanted to use royal purple this time but I'm not sure if people were use 10w30 motor oil or 75w-90 gear oil. can anyone help me?
I put in Redline MTF 75w90 in my SiR tranny...shifts like butter and it's probably the best transmission I've ever used...ever. 2 Bottles, I need to buy another one so I can put a little more in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipkc »</TD></TR><TR><TD CLASS="quote">I put in Redline MTF 75w90 in my SiR tranny...shifts like butter and it's probably the best transmission I've ever used...ever. 2 Bottles, I need to buy another one so I can put a little more in there.
75w90!?! You are recommending oil that is thicker than Honda says to use?
Back before Honda made their own MTF, they used regular 10w30 in their 5-speeds. Using normal non synthetic, non high mileage type conventional 10w30 motor will not hurt your 5-speed tranny.
I have used Honda MTF and GM Syncromesh and felt no difference in gear engagment smoothness. /.02
</TD></TR></TABLE>75w90!?! You are recommending oil that is thicker than Honda says to use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. »</TD></TR><TR><TD CLASS="quote"> you should only need 2.5 quarts</TD></TR></TABLE>
Most take 1.9 qts.
Most take 1.9 qts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">75w90!?! You are recommending oil that is thicker than Honda says to use?
X2, 75w90 is thick, really thick, even snow plows usually only run about 50 weight motor oil in their trannys. For some reason toyota specs 75w90 in their light trucks though.
10w30 or honda MTF is my recomendation.
</TD></TR></TABLE>X2, 75w90 is thick, really thick, even snow plows usually only run about 50 weight motor oil in their trannys. For some reason toyota specs 75w90 in their light trucks though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My JDM EJ8 »</TD></TR><TR><TD CLASS="quote">so royal purple 10-30</TD></TR></TABLE>
Should be fine, although personally i've heard great stuff about honda's own MTF, haven't actually tried it yet so I can't comment on it.
RhombeusGSR
Jun 28, 2004 12:02 PM
civichb92
36
Oct 19, 2003 06:32 PM
