Need a lil advice on body work
Old Oct 30, 2008 | 10:49 AM
SIRIUS VTEC's Avatar
Default Need a lil advice on body work
So i took it upon myself to sand down my car. which was originally a sunset orange color.
On the passenger i think i sanded a lil too much, a lot of bare metal points.
What i need to know is, when i go over these bare metal points to straighten out the body, i have to use bondo?
More so, what type of bondo works better over bare metal?
Im just a lil curious because i dont wanna mess it up too bad, but from the look of it imma need alot of bondo cuz it's alot of bare metal points. I took this lesson and on the driver side i didnt hit bare metal at all and the body on the driverside is sanded but very smooth so that side's pretty much ready to go.
I dont like the idea of using bondo but this car was practically already on it's way to f*ckvill with the body work that was already done to it.
Can anyone give advice as to where i go from here? like what kinda bondo to use on the bare metal and how much to use?
Old Oct 30, 2008 | 11:37 AM
bondo and filler are much of the same thing right? imma just go with filler..but which kinds good? i was reading up on self-etching stuff but that's primer..
Old Oct 31, 2008 | 01:38 PM
99sohcaccord's Avatar
use evercoat filler plus fill the area well enough to cover the dent or whatever bc u will end up sanding most of it off anyway but b careful not to go to deep as u will have to use filler again a little goes a long way just make sure its smooth with the panel itself no bumps or grooves then primer/sealer right after or u will have some surface rust (which will sand out) to cover the entire areau can use a flexible sanding block to get the lines right they will form just dont rush or use a ton of pressure on it. it takes time and patience but it will come. just b patient.
Old Nov 2, 2008 | 04:45 AM
19civic93's Avatar
Default Re: (99sohcaccord)
Right now you are working blind. You need to start blocking this car. Fill in any low spots and sand it smooth then prime the area. Next do a guide coat and sand until the the guide coat is gone. This will reveal the high and low spots that still exists. You may have some high spots that may need to be pounded down a little. The low spots shouldn't be that bad if you were thorough in the first fill so you should be able to fill with polyester finishing putty. I use evercoat and it's called glaze coat. You can apply right over primer. After you fill sand it smooth, prime, and block again. Repeat untill you are confident that the body is straight.
Old Nov 2, 2008 | 08:01 AM
Wakes4Fun's Avatar
Default Re: (19civic93)
Just take a can of flat black paint and "spatter" the paint onto the panel, block sand and then you'll be able to see all the dents in your panels.
Old Nov 2, 2008 | 09:14 AM
precisionsc54's Avatar
Default Re: Need a lil advice on body work (SIRIUS VTEC)
1st thing what the h*ll did you sand that with? Dont even tell me a da!!! That is gonna be a pain in the *ss to straighten out now. You have diff heights on the entire quarter panel now. My suggestion is this mask off the car and shoot about 3-4 coats of high build 2k primer on the entire quarter panel. After thats dried mist the quarter panel with black rattle can . Then start sanding with some 320grit on a long block. If there is still some black left when ur done those are your low spots that will need actual body filler. If you need to know more pm me. Later kid
Old Nov 2, 2008 | 01:15 PM
Rukusmasta2's Avatar
Default Re: Need a lil advice on body work (precisionsc54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precisionsc54 &raquo;</TD></TR><TR><TD CLASS="quote">1st thing what the h*ll did you sand that with? Dont even tell me a da!!! That is gonna be a pain in the *ss to straighten out now. You have diff heights on the entire quarter panel now. My suggestion is this mask off the car and shoot about 3-4 coats of high build 2k primer on the entire quarter panel. After thats dried mist the quarter panel with black rattle can . Then start sanding with some 320grit on a long block. If there is still some black left when ur done those are your low spots that will need actual body filler. If you need to know more pm me. Later kid </TD></TR></TABLE>
agreed
Old Nov 4, 2008 | 07:36 AM
dividedas1's Avatar
Default Re: (Wakes4Fun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wakes4Fun &raquo;</TD></TR><TR><TD CLASS="quote">Just take a can of flat black paint and "spatter" the paint onto the panel, block sand and then you'll be able to see all the dents in your panels. </TD></TR></TABLE>
the backyard body man's guide coat
Old Nov 5, 2008 | 06:17 AM
Wakes4Fun's Avatar
Default Re: (dividedas1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 &raquo;</TD></TR><TR><TD CLASS="quote">
the backyard body man's guide coat </TD></TR></TABLE>
Hell Yeah, ****'s works awesome tho. I actually know a bodyman who works for a Ford dealer who still uses this method instead of guide coat.
Old Nov 5, 2008 | 06:19 AM
dividedas1's Avatar
Hell Yeah, ****'s works awesome tho. I actually know a bodyman who works for a Ford dealer who still uses this method instead of guide coat. </TD></TR></TABLE>
meh its okay for someone who has time to wait around... stupid *** spray paint never dries quick for me. if you don't give it enough time to dry it just gunks up your sand paper. it definitely gets the job done though if you give it plenty of time to dry.
Old Nov 5, 2008 | 01:54 PM
Lifesmystery's Avatar
cool
Old Nov 5, 2008 | 05:04 PM
should be dry enough to wet sand within a few minutes. If not you need cheaper spray paint or your spraying it on 2 thick.
Old Nov 5, 2008 | 09:03 PM
dividedas1's Avatar
Default Re: (precisionsc54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precisionsc54 &raquo;</TD></TR><TR><TD CLASS="quote">If not you need cheaper spray paint </TD></TR></TABLE>
bah thats true... the cheap **** sanded really fast. then i had some left over flat black rustoleum that took forever to dry.
evilclown312
Paint and Body
Jun 27, 2012 12:06 PM
SlammedEG6
Paint and Body
15
Jan 31, 2010 10:12 AM
bucksarge
Paint and Body
Jan 28, 2009 03:17 PM
Mike banX
Oct 29, 2003 05:19 PM
Audipwr1
May 8, 2003 08:27 PM
