check engine light on PLEASE help
Old Oct 30, 2008 | 09:20 AM
JDM EF CR-X's Avatar
Default check engine light on PLEASE help
Hey guys i have a check engine light on n maybe u can help me ...... i checked the codes n i have 2 i have a 4 CKP Sensor (Crankshaft Position Sensor) anf its also throwing a 20 Electrical Load Detector i have crx wit ls/vtec i also have a chipped p28 wit a neptune program ..... and idk y but since that ma car wont rev past 3500 rpm's so any thing will help thanks guys ...........
Old Oct 30, 2008 | 09:25 AM
jdmed3's Avatar
Default Re: check engine light on PLEASE help (JDM EF CR-X)
its your ecu who did your chip and tune... my friend tried doin a mugen chip in a p28 and wired it wrong by 1 spot and it only ran up to 3800 wat that is is safe mode cuz the car doesnt know what it can do basically and the crank your gana have to wipe your codes and drive and see if it comes up again and if so then you will have to pull and rebuild your block make sure everything is torqued down right and not sittin wrong... how does it run generally
Old Oct 30, 2008 | 09:56 AM
Default Re: check engine light on PLEASE help (jdmed3)
well i have tried 3 diff ecu's n all have brought those codes n isnt the 4 CKP Sensor (Crankshaft Position Sensor) in the dizzy ?
Old Oct 30, 2008 | 09:58 AM
it runs really good like it doesnt choke or anything i jus cant rev past 3500
Old Oct 30, 2008 | 10:54 AM
jdmed3's Avatar
all the ecu's wont let you rev past 35? hmm try reseting it (taking out the ecu fuse for 10 sec) after you plug in an ecu and try reving it... any check codes?
Old Oct 30, 2008 | 10:57 AM
right when i start the car it throws a CEK
Old Oct 30, 2008 | 10:58 AM
CEL not CEJ ma bad
Old Nov 7, 2008 | 09:16 AM
jdmed3's Avatar
wats the code number and i'll see what i can find out
hergizzal
Feb 10, 2010 02:34 PM
xXCarfreakXx
Aug 9, 2008 11:54 AM
T3T495GSR
Sep 27, 2007 06:42 AM
HondaHero
Apr 28, 2007 08:52 PM
hatchboy93
14
Apr 23, 2003 10:02 PM
