check engine light.
Old Apr 26, 2007 | 08:08 PM
HondaHero's Avatar
Default check engine light.
I have a 99 gsr with ls/vtec swap. also a tuned p28. the check engine light came on and i ran the code with a stock gsr ecu. it threw a throttle position sensor, after replacing check engine light still on. Ran the codes again and it threw a crank position sensor, but my car still runs. I tried disconnecting the battery with the obd1 ecu but still no luck.maybe t is just the obd2 throwing false codes but if so why is the check engine light on with the tuned p28? anything to trouble shoot will help.
P.S. I am new to this sight but have some knowledge and experience. Willing to help with any problems I am familar with and know about.
Modified by HondaHero at 9:50 PM 4/28/2007
Old Apr 27, 2007 | 08:41 PM
HondaHero's Avatar
Default Re: check engine light. (HondaHero)
sovled my own problem. i was runnin codes with a gsr ecu, but running ls/vtec. so it was throwing the crank sensor code because the ecu cant read a ls motor, because the crank has a longer stroke. real problem is when i pt in a new tps sensor i didnt adjust it right so after fine tuning everything went right.
Modified by HondaHero at 9:51 PM 4/28/2007
Old Apr 27, 2007 | 08:51 PM
sPaRk'iT's Avatar
Its VTEC not vtech.
Old Apr 27, 2007 | 08:59 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHero &raquo;</TD></TR><TR><TD CLASS="quote">sovled my own problem. i was runnin codes with a gsr ecu, but running ls/vtech. so it was throwing the crank sensor code because the ecu cant read a ls motor, because the crank has a longer stroke. real problem is when i pit in a new tps sensor i didnt adjust it right so after fine tuning everything went right.</TD></TR></TABLE>
that still makes no sense
Old Apr 27, 2007 | 09:38 PM
1998b18c1's Avatar
Default Re: check engine light. (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT &raquo;</TD></TR><TR><TD CLASS="quote">Its VTEC not vtech.</TD></TR></TABLE>
i was going to post the same quote---plz if u so called know honda/acura use the right term. vtech is on toys and house phones.
Old Apr 28, 2007 | 08:30 PM
HondaHero's Avatar
Default Re: check engine light. (1998b18c1)
my bad foo i second guess myself alot when im typin ****, im a bad speller. and i dont proof read just type. calm down.
Old Apr 28, 2007 | 08:35 PM
HondaHero's Avatar
Default Re: check engine light. (doood)
how does it not make sense, i was using a gsr ecu to run codes on a ls. Because the ls crank has a different stroke the ecu was throwing another code. I realized this when i used my friends itr ecu and all it threw was a tps code and that was what is really wrong.. and damn mybad for sayin VTECH i was diff. typin to fast and not really thinkin, had a college exam. Sorry everybody who read my post and saw that **** its embarrassing. I shoulndt of even posted anything when i was in a hurry, cz **** like that point thank for pointin it out.
Old Apr 28, 2007 | 08:52 PM
HondaHero's Avatar
but thankyou for pointing it out
xXCarfreakXx
Aug 9, 2008 11:54 AM
kaoss_11
Sep 10, 2006 04:14 PM
lsvtecdude
Aug 13, 2005 05:24 PM
hatchboy93
14
Apr 23, 2003 10:02 PM
