Main bearing/Rod bearing codes
Yes, i tried the search, its fooken brooken, and my haynes manual sucks. I dont understand the codes that are on my crankshaft on my d16a6 engine, these are the ONLY numbers/letters i see....
C 2 B 2
B 3 B 2
So these would be my main bearing codes or what? I heard that there are also codes on the block, but i can't see any, even on the mating surface of the block/oil pan...can you guys help me out?
Edit: C2---2 upper left, B----3 bottom left, B-----2 bottom right, B----2 upper right.
[Modified by RedRacerCivic, 8:55 AM 7/30/2002]
[Modified by RedRacerCivic, 9:00 AM 7/30/2002]
C 2 B 2
B 3 B 2
I don't have alot of experience on D series, but B series have letters on the block for the crank journals and numbers on the crank. For the rods there are the numbers on the rods and letters on the crank.
The Bseries letters are on the back/bottom of engine block on the tranny end. There will be 5 letters. 1 for each rod journal and 1 for each end.
Hope this helps.
Thanks, J
Hope this helps.
Thanks, J
brokenojoke
Dec 22, 2005 09:25 AM
canuck-mx6
Jun 3, 2002 04:38 PM
