Can one remove key marks?
Old Oct 30, 2008 | 07:52 AM
MSchu's Avatar
My Name is Nobody
Default Can one remove key marks?
Like this? The scratch goes into the paint.
I have read that you can fill it with touch up paint then micro sand it out and wax...
what happens to the clear coat in the area after you have wet sanded it? how you repair that clear coat?
thanks
Schu
Old Oct 31, 2008 | 12:40 PM
MoreBoost!'s Avatar
Default Re: Can one remove key marks? (MSchu)
i done this before, just sand LIGHTLY with 1500 or 2000 grit sand paper(use a block sander not your fingers) and keep filling in paint where it is needed. the clear coat around the area should be fine as long dont cut too deep and into the paint. then i used a buffer, polish and wax from wal-mart n buffed it till it shine. 6 months now and no problems with oxidation or anything
Old Nov 1, 2008 | 09:21 AM
HondaH22a#1's Avatar
Default Re: Can one remove key marks? (MoreBoost!)
bump i need to know this too!!!!
Old Nov 2, 2008 | 01:42 PM
stiffdogg06's Avatar
Default Re: Can one remove key marks? (HondaH22a#1)
-Buy OEM touch up paint. Make sure if you have pearl/metallic to shake the paint really well before using it to make sure u get pearl on the brush.
-Buy Mequiars Uni Grit 1500-3000 grit
-Sand it even with the paint
-Buy quality polisher/polishes
-Apply some clear to the touched up area
-Sand more
-Polish to remove sanding marks.
That's basically in layman's terms.
Old Nov 2, 2008 | 04:16 PM
SoCal EJ1's Avatar
it's difficult to see in the picture, but does it go through the clear coat and stop in the paint, or does it go through the paint into the primer?
rudebwoy
Paint and Body
22
Sep 8, 2015 03:38 PM
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
EK_B
Paint and Body
Apr 23, 2008 02:21 PM
suko69
Paint and Body
Sep 18, 2007 03:40 PM
AssPenny
Aug 28, 2002 04:36 PM
