Speedometer, Odometer and Trip meter don't work
Hey guys hoping someone can help me with this.
My speedo odo and trip meters don't work they just stay at zero the whole time and never move.
Ive replaced the VSS and cluster and still have nothing. i don't have a CEL so im not sure what is up.
please help! car has to pass safty by monday
hey im having sorta the same issue xept my rpm's r cool til like 3k and then they spike up and down and fluctuate as well as my odo.. they keep going up and down all crazy. i already changed the cluster and the vss as well.. tranny was changed as well and still doing this .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr »</TD></TR><TR><TD CLASS="quote">^ usually this kind of **** is caused by bad ground points. maybe crud is covering your sensor.</TD></TR></TABLE>
checked all the fuses they look good. found something fishy though with the engine harness for some reason the alternator plug is cut that the wire are spliced directly to the drivers side wires and go right into the car.
my question is does the speed sensor go right into the cluster?
bones91
Sep 27, 2005 10:36 PM
